Question about Logitech FreePulse Wireless Consumer Headphones
Only have sound from the right speaker
I use my headphones mainly for workout purposes only. this morning while going for a jog the left speaker began to short out a bit, then it began to play but sounding like the speaker was blown until there was no sound at all... does anyone have any suggestions?
  • Arun985 Feb 27, 2008
    I purchased the Logitech FreePulse headphones about a month and a half ago, and until now they've been working amazingly. Now, however, the right side speaker has trouble producing sound and sounds kind of like static. The speaker is not completely though, because it does produce sound when I futz with the transmitter. And its not a power issue because I recharge the headphones and transmitter every night. Is there anything I can do to fix this problem?
  • jamesmoroni Apr 26, 2009
    I have the same problem in both of my freepulse sets. Seems like a loose connection inside the transmitter.
    Genius:
  • 1,003 Answers
IF these headphones are wireless try recharging if they are not wireless you may have a shorted or blown speaker
Posted on Jan 23, 2008
Sound coming through right headphone, but not through left. Sound also not coming through left speaker. Help?
are you adjusting sound through the windows controller or the application you're playing music through? there are a few things that could affect that, there's also the actual sound setup where you can change your setup i.e. surround sound, single speaker, headphones etc
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Oct 02, 2013 | Toshiba Satellite Computers & Internet
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
Altec lansing vs4121 speaker boom sound
you may have blown out the speaker or there is a miscommunication between the laptop and the woofer
Jun 15, 2012 | Altec Lansing VS4121 Speaker
Can we jog with baby on a Bugaboo Cameleon?
All depends on the quality of your local sidewalks! Lock the front wheels and tilt back when coming to any irregular surface. The Bugaboo is a versatile stroller but not really the best choice for jogging.
Jul 28, 2011 | Bugaboo Cameleon Jogger
How do i wire the second speaker so they work as a pair
there is a black cord that comes with the speaker system with dual end headphone 3.5mm jack both ends that go from one speaker to the other main speaker is your right speaker left is the one with only jack insert the right has da power with sound cord toghether in one going out to amp with headphone insert also that goes to left peaker
Dec 18, 2010 | Philips MMS 321 Computer Speakers
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Sound to compputer headphones stopped working
go to main screen panel, then go to speaker icon, right click, go to properties, make sure headphones are enabled, volume is turned up, and see if the headphones are set as default. Update drivers if necessary
Aug 27, 2009 | Audio Players & Recorders
No sound from headphone
Worse case scenario is that your left speaker is gone but usually what happens is a break in the cable someplace.Are you using the 1/8" plug or are you using them with the 1/4" adapter. The 1/4" adapter might be worn out but is easily purchased and replaced.The cabling from the plug runs into the left can and from there splits into left and right speakers. There will be a wire that follows the head band under the cushion from left to right. With these headphones there is a swivel above the can and the problem might be in there. Half the problem is getting at the wiring to test it. Usually the plate that the speakers are mounted on is screwed to the back cup and the screws can be reached by removing the earpad. You will need a volt ohm meter to test the wiring. You can also test the speakers with it. Unfortunately most plugs on headphones are molded onto the cable so you will have to start by testing from the plug to the left can. Inside the left can will be a junction point where the main cable feeds the right speaker. Test up to there for right and left and if the connections are good then test the speaker. Hope this helps.
May 14, 2009 | Audio Players & Recorders
I own a Sony-Ericsson P1i. Its sound volume is very low and though I have kept it on the maximum, I can barely hear the opposite person talking to me. But the music volume is okay, and so is the headphone...
I had this problem too but i found this on the web so i'm gonna copy paste . Good luck!
"The low volume in the in calls in SE P1 / P1i can be easily solved in this way/hack:
(Thanks to montsma, the Junior Member AT noeman.org)
Speaker volume in P1i Service Menu
Go to the Main Menu > Phone > Phone to open the virtual numeric keyboard.
Do the following;
- 1 click up on jog dial and press (*)
- 2 clicks down on jog dial and press (*)
- 1 click down on jog dial and press (*)
to open the hidden Service Menus part of the phone.
Then go to the Service Tests > Speakers.
There are two selections, rear and front, and the "front" adjusts the volume of the ear speaker, which is used during the calls. Increase the volume to %100. Quit the Service Menus and make your call. I made one try and it was cool!"
Apr 03, 2009 | Sony Ericsson P1i
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Logitech FreePulse Wireless  Consumer Headphones Logo
386 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
