Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Can not connect to router via a wireless connection.
I am trying to create a home network with 2 computers. I comp has vista and one has xp. One is connected via a lan connection and the otther a wireless connectionI have a d-link 624 router and virgin broadband cable modem.
It took me a lot of trial and error to get the modem and router to talk to each other but I finally managed to get an internet connection through LAN. I think this is because the inernet was originally established on the computer before the router (introduced at a later date). However I am unable to connect to the internet via a wireless connection on a 2nd computer. I can see the network in available networks but it will not connect. I have left the network open security to eliminate this as a factor.
Please help!
  • buck1965 Jan 26, 2008
    can not connect to internet via router. I have tried reset , I have tried uninstall with the wireless program, am able to create network ,still unable to connect to internet even with security disabled. help!
  • 33 Answers
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Posted on Feb 07, 2008
My comp will not connect to my wifi linksys router, net work is up internet provider transfered me to linksys who wants to charge me $75 to fix, what do I do??
What is the Operating system on your computer ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
Unable to conect wireless computer is saying cannot display the webpage
Check the configuration
Check if you have created a wireless network
If XP/Vista OS then connect the wireless connection
Try to check DMZ settings as well
If not change the wireless network name and channel and try with it
Jan 13, 2010 | NetGear WGR614 Wireless Router
Connect a router
Are you trying to set up the router ?
Or you are trying to connect to the wireless network.
It is very easy to set up the router.
I hope the following link will help you
Click Here for step by step solutions
Nov 06, 2009 | Linksys Wireless-G Broadband Router
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network Tasks..click..Create A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Vista wireless networking with 2 computers cabled to router
To disable the ( redundant ) wireless connection, right click ' My network places' click properties, in the dialog right click your wireless connection, click disable. YMMV in Vista. There are several ways to disable an adapter, might try Windows Help.
If your "someone" installed Norton AV that's what degraded your performance. Remove it and pick one of the free ones like Avast or AVG. If the previous AV wasn't removed properly you're going to see a slowdown.
Dec 26, 2008 | Microsoft Windows Vista Home Premium with...
Wireless
Make sure the Vista driver for your wireless G USB adapter is installed. If not, you can download it from the manufacturer's website
Mar 27, 2008 | Belkin (F5D7230-4) Router (587009)
Vista OS can't connect wireless to Dlink DI-614+ rounter
yes it does but what exactly is this it's your comp that's not connecting to your wireless network..so here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Feb 18, 2008 | D-Link AirPlus DI-614+ Wireless Router
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
163 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
