Question about Acer Aspire 3610 Notebook
Acer Aspire 3610
Whenever I try to start up my laptop it starts to boot up. In the processing of booting it will restart itself over again as if you just turn the laptop on. I never get a chance to get to the login screen and the monitor on the laptop does show symbology but no login screen. I tried erasing the software and putting it back on but it didn't work. Can you help?
  • 86 Answers
How far does it get in booting. Do you see the Windows screen with the side scrolling bar before it reboots. During the boot process, start hitting the F8 key once a second until it drops you into a menu where you can select to start in Windows with safe mode. If you cant get that far, hit the DEL key a few times a soon as you boot the computer to try to go into your BIOS. If you can get into either of these, I may be able to help you.
Posted on Jan 23, 2008
Acer aspire 6930 will not boot
restart the laptop then at the time of booting press F8 / F2 then a screen shows and there shows " Last knwon good configuration " go over this select and press enter ur system will be boot .
If ur system not boot in this process then take backup and format the laptop.
Oct 07, 2012 | Acer Aspire 6930-6455 Notebook PC
My acer aspire will not boot up. After starting the process it flashes a quick screen with an error for registry file failure and restarts boot process
As it starts up.. hold down F8. An option for a Safe Mode should be available. You should choose that and once you get through to Windows go to Start > Run and type in "chkdsk c: \r"
Jul 07, 2011 | Acer Aspire One PC Notebook
Erecovery acer 5315
You can "try" to stop the process from starting by unchecking the appropriate box under boot menu.
go to RUN, type MSCONFIG, check the startup tab.
Hope this helps.
Jun 15, 2009 | Acer Aspire 5315 Notebook
Boot problems with Acer Aspire 3610
do you have power ? if no, check your power outlet and ac adapter first, if both of them are ok, it could be your motherboard.
if you have power but no display, this is called no post.
reseat your memory. if still not working, use 1 memory and try to put it in different ram slot. and if this is still not working, your motherboard is bad
Jul 26, 2008 | Acer Aspire 3610 Notebook
Acer aspire 3610 not booting pass flash screen and if it does gives an error openning windows
try by changing the data cable and check the jumper setting of the hard drive
May 12, 2008 | Acer Aspire 3610 Notebook
you can reinstall os with ur xp.
with xp disk in drive at startup do you get option to boot from cd.
if not go into bios at startup and enable cd boot in boot options as first;save and exit;restart.
I assume you know how to install windows(xp)
Mar 03, 2008 | Acer Aspire 3610 Notebook
Acer 3610
I THINK YOU NEED TO UPGRADE MEMORY AND RELOAD YOUR SYSTEM FROM YOUR RECOVERY DISC THAT CAME WITH YOUR COMPUTER.
IF TIS DOESENT WORK REPLACE YOUR HARDDRIVE
Jan 23, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
