Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
My sony kf-50XBR800 tv turns itself on and off continuously. Put it on, stays for 30-60 sec, then no picture, audio stays on 1-2 seconds then totally off. The red light blinks 34 times, then comes back on and the cycle repeats until I either unplug it, or manually turn off. I've been searching the net, maybe the lamp, but lamp light doesn't light. Heard about thermal fuse issues. The set was purchased in 2003, never replaced the lamp. Any thoughts??
  • hueybaby328 Jan 26, 2008
    Thanks for the suggestion. I did some research, and purchased a new lamp. Installed it last nite, seems to have solved the problem. Thanks again.
  • THanlon Jan 27, 2008
    I have the same problem. So, if I read this right, you simply replaced the bulb (presumably for about $200), but that was all that was required to resolve the issue?? I really don't want to pay for a service call (on top of bulb price) if that's all it takes.
  • Sony Master
  • 8,617 Answers
Check PS1601 and PS1601 on the reverse side of the G board these are ceramic IC links (fuses rated at 2.5 Amp @50V)
Posted on Jan 23, 2008
4 Suggested Answers
SOURCE: sony kf-50XBR800 tv turns itself on and off
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
Posted on Mar 14, 2008
  • 8457 Answers
SOURCE: kf-50xbr800 turns off for about
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Posted on Aug 22, 2011
  • 7 Answers
SOURCE: Sony grand wega started turning on and off continuously
The usual problem is that the lamp needs to be replaced. However, there is no guaranty that lamp replacement will correct the problem.
To figure out how to replace the lamp please visit
The frequently asked questions for Grand WEGA KF50XBR800 50 in. Rear Projection
http://www.agoraquest.com/viewforum.php?forum=70
Posted on Jun 12, 2008
Tv won't turn on.
It sounds that the main board if faulty. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy.
Apr 21, 2013 | Sony KF-50XBR800
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
I have a sony LCD projection TV Model # KF-50XBR800 and when I go and turn it on my standby button flashes red and then picture comes on for about 10 seconds then it shuts itself off. Can you tell me what...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 28, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
When I turn my Sony Grand Wega Kf-50XBR800 on,
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety.
Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy.
Thanks.
Oct 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony kf-50XBR800 tv turns itself on and off
Jan 24, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
codes consist of N blinks, a pause and N blinks again,valid error codes are 3, 4, 5, 6 & 9 blinks.
Jan 23, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony tv will not stay on
unplug the unit for a couple of minute and plug it back in...if it still wont stay on get a repairman
Jan 23, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
416 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
