Question about HP Pavilion dv6000z Notebook
15-in-1 internal memory card reader
I would like to how do you connect the 15-in-1 internal memory card reader to the motherboard its got 2 cable attached to it.
  • rickyx Jan 24, 2008
    It is a Sony 15-in-1 memory card reader and it has got two 4 pin USB type A pinouts. How do I connect it to the 10 pin USB 2.0 pinouts on my motherboard.
  • Salehe Kungule
    Salehe Kungule May 11, 2010
    can you tell the type of the card reader you have?
You should connect it by the scheme VCC | Data - | Data + | Ground.
In most motherboards you have connector something like this
By this scheme the first one is vcc and then by the scheme
i`ve attached.
If you can, show please screenshots of your connector on card reader!
Posted on Jan 25, 2008
How to transfer internal memory pictures to computor
You have two options:
1) Remove your memory card from the camera, if you have one. Then connect the camera to your computer using the supplied USB cable.
2) Use the "Copy" command in the Playback menu to copy the pictures from the internal memory and then download the pictures from the memory card. Once the card is plugged into a card reader attached to your computer, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.
If you need a manual, you may download a copy from here.
Sep 16, 2012 | Nikon Coolpix S9100 S-9100 26248 Black Hd...
Coolpix s9100 transfer internal memory photos to computor
Sep 16, 2012 | Cameras
How do I transfer my pictures from the internal camera memory onto the computer?
One of two ways.
1) Remove the memory card if one is installed. Connect the camera to the computer using the USB cable. Transfer pictures normally.
2) Copy the pictures from the internal memory to the card, then take the card out of the camera and plug it into a card reader. Transfer pictures normally.
To copy pictures from the internal memory to a card, press the playback button (right-pointing triangle) to enter playback mode, press MENU, then select "Copy".
You can use the USB connection or the card reader, whichever you're more comfortable with, whichever you normally use.
Oct 18, 2010 | Nikon Coolpix S3000 Digital Camera
I would like to install a internal card reader with a usb port.
Those wires go into an internal USB extension connector - which your motherboard doesn't have. Get a PCI USB card and connect them to it - this way you will also get USB2.
Mar 10, 2010 | Chaintech CT-6OJV2 Motherboard
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Connecting a card reader to the mB
Most multi card readers are usb, but not the external kind that fits in the back of the motherboard, the internal kind.
If you look at the edges of the otherboard you will see three small blue connectors. Those are internal USB connectors, it should say next to them. Plug it in the correct way round (it will only go in one way) into any one of the three.
Dec 02, 2009 | ASUS P4PE/L (ASU49J) Motherboard
I get to the splash screen then it locks up!!!
does the hd disks and drives reconized on bios scren? problebly some hd drives has fatal failure, and lock bios, try remove hd cable, and test
if not try to change memory for new ones ( same types has manual spec.)
remove usb cables internal cards readers (low quality cards readers has normaly freezes bios)
Nov 22, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Internal memory card reader plug on the MB?
The memory card reader that you have is most likely running on USB, therefore you will need to plug it in to one of the USB headers on your motherboard. They usually are made for 2 USB ports so the connector for USB is 2 rows, but yours is just flat so it will fit anyway.
The USB plug and cable on the motherboard kind of look like this:
http://www.windowsdevcenter.com/windows/2005/02/23/graphics/figure14.jpg
Dec 08, 2008 | EliteGroup 845GV-M3 Motherboard
HP Pavilion dv6000z Notebook Logo
141 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
