Question about Peavey Escort 2000 Microphone
Low volume from CD and iPod input
My Peavey 2000 is great for my daughter's vocal perfromances, but I'd like to understand the differences in the power of her accompaniment music from different input sources. For example, her CD (a portable, walkman-type device) and her top-of-the-line iPod don't produce enough volume through the Paevey 2000 as accompaniment music for her vocals, while her small "boom box" Sony does. Is the difference just attributable to the low power output of the iPod and the portable CD player while the boom box has higher power output? Is there a way to boost the signal from either? The iPod, by the way, plays through my B&O home stereo system just fine but, using the same cables, just doesn't do the job with this nice Peavey 2000.
  • 682 Answers
In audio system you have three different levels.
1-mic level which is very small output level.
2-line level(like cd player output)which is higher than above.
3-speaker level is highest one which drive speaker and get sound out from it.
if you want to get control for number 1 and 2 you can use very simple sound mixer.(from radio shack-or other electronic store)
connect your sound source(mic-cdplayer)to the mixer and get out from mixer to amplifier.
Posted on Apr 26, 2008
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
Speaker rattle
Yes, but you need to replace the entire speaker. The 1505 and 1508 use a different magnet though they look similar..
Jan 20, 2014 | Peavey Music
Low output with high volume
sounds like distortion is being caused by trying to amplify a low volume level from the input device. try putting the ipod volume at a medium level and try again to see if the distortion goes away/reduced
Dec 23, 2013 | Pioneer Avic-940bt Car Navigation Cd/dvd...
I have a new Peavey XR1220P powered Mixer purchased March 31/12 with no manual. I have hooked it up, but have one problem to solve. The low impedance inputs are not sending sound to the main speaker
Where is the gain set for that input channel of the low impedance mics? If you have an unbalanced Hi-Z input sharing a channel with a low Z balanced microphone They are sharing the same gain stage op amp- in which case an unamplified microphone loses.
Apr 01, 2012 | Music
I have a Peavey 8600 amplifier. It sounds great but when only operating vocals, in order to get the highs of your voice just right, the speakers put off a large amount of white noise. While singing, you...
There is not enough info here to provide a complete answer, but let me give you some background:
There will always be some hiss. This is due to general amplification where a small amount of noise is amplified along with the general signal. In most cases, the signal is strong enough to overpower any noise that is present (vocals in your example). This noise should not be that noticable in normal cases. If there is an automatic gain control in the line, this could account for it as with "silent" times, the gain will automatically be increased potentially to the degree where the noise is noticable.
Barring that scenerio, if the input signal is too low, the overall gain necessary to produce reasonable volume at the speakers will also be such that the noise is noticable. In order to track this down, please provide details about the current setup including:
1) Microphone make and model being used
2) Input being used on the mixer
3) Gain level being used for the mic channel
4) Gain level being used at the master level.
Dan
Jan 07, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
How do i connect the cables between peavey vocal effects (ultraverb II) and PA (peavey xr500c)
if you mean effects loop try graphic out to ultraverb input and output to power amp in. this will effect all channels of the xr500c
Jan 01, 2010 | Peavey Music
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
How to connect mixer an amp to laptop?
How is everything hooked up?
Mic to Mixer, and Mixer to Laptop? Or is your mic connected directly to your laptop?
To do this properly, you will need a secondary audio input device of some kind that accepts line level input. Microphone inputs are intended for low level signals, and are not going to accept the input form a mixer properly. (you can get it to work, but it will generally be distorted)
There are various USB or PCMCIA audio input card options that aren't too expensive. Once you have that, you would need to route your music and microphone through your mixer, and the output of the mixer to your audio input device.
Mar 20, 2009 | HP Pavilion dv9000z Notebook
Connecting cd player to mixer
This should work. I use a similar setup for break music at small gigs. I would check the cable and the output of the unit itself again. .
Feb 21, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey Escort 2000 Microphone Logo
145 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
