Question about Navman PiN 570 GPS Receiver
NAVMAN 570 PIN
MY NAVMAN IS COMPLETELY DEAD PLUGGED IN THE GREEN CHARGING LIGHT WONT COME ON
  • Anonymous Mar 26, 2008
    Same problem here
Forget it the charging socket/circuit is stuffed!
Did the same as suggested and also brought a new battery but no good.
I "hard wired" it so it has now a GPS only.
What a stupid plug they came up with (so much for supporting Kiwi made)
The amount of stress that is placed on the plug while its pllugged in and your driving,something has to give sooner or later.
Posted on Jun 26, 2008
    Problem Solver:
  • 12 Answers
Maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Posted on Mar 30, 2008
My Pin 570 works fine except for its inability to log on to the satellites. I know that the antenna is working fine. Mike
if you click your windows icon and select from the dropdown box, Settings, then click system, then gps and click on, then exit completely and try again.
Feb 04, 2010 | Navman PiN 570 GPS Receiver
Charging light not coming on
I had the same problem, took the thing apart and checked voltages with a multi meter the battery voltage was 1.5 volts checked all connections nothing wrong put it back together" no go" held the reset button for over a minute, lovely green flashing light! hope it works for you
Jul 03, 2009 | Navman PiN 570 GPS Receiver
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
Won't Charge
You need to change the battery. It is not a fun thing to do. Do a word search for Navman PIn 570 Replacement battery either on Google or Ebay. You have to disassemble the unit to get to the battery that is taped to the unit's motherboard. There are hidden screws on the back of the unit, then you have to gently pry the 2 halves off. Big Heads up here: the round dial on the left side...be sure to tape that in place when you first disassemble the unit, otherwise it falls out into 2 or three pieces...that dial is a pain to get back together if you do not tape it.
I recently replaced the battery on my unit. There are two additional screws on the back of the unit, near the bottom in addition 2 screws under the flip up antenna. They are covered by small black plastic discs which need to be pried off first. After removing the rear cover with a knife edge (or similar) there are several other screws which attach the circuit board to the front of the unit which need to be removed. Note that the one near the edge should only be loosened, and the board slid out sideways. Once this has been done you should be able to access the battery which needs to be pried off the board, as it is attached with an adhesive patch.
(If the battery is totally dead it takes about a day before the charge led starts flashing.)
May 20, 2009 | Navman PiN 570 GPS Receiver
Pocket pc navman 1022 charger and charger jack pin
sir, i have pocket pc 1022 navman pin 570 is not connecting with my pc.
May 16, 2009 | Navman PiN 570 GPS Receiver
Charging socket has come out
DOnt know where you can get it fixed but I "hard wired" it so it has now become a GPS only.
Jun 05, 2008 | Navman PiN 570 GPS Receiver
Pin 570 not charging
the connect where it plugs in is very flimsy you may need a new one. try adjusting the angle etc at which you place the unit on charge its very fiddly to get it right and a small nudge loses it
May 30, 2008 | Navman PiN 570 GPS Receiver
Pin 570
Start Here:
http://www.navman.com/
Then select your region. They have an online store to buy whatever you need.
Cheer mate,
Worldvet
May 24, 2008 | Navman PiN 570 GPS Receiver
Charging socket on navman pin 570 has come out
These sockets are on sale if you google enough. Ebay seller totalviews for example. Check its the right socket and be prepared for very small presise soldering. when you open the case, take great care not to break/dismantle the rocker switch that protrudes as it has minute elements in it. If charging is a problem but the socket appears sound,m check the plug that goes into it and ensure the springs go in and out to hold it in place.F4therchristmas
May 19, 2008 | Navman PiN 570 GPS Receiver
NAVMAN PIN 570
Try cold boot, that is factory reset button on the right of the power/usb cable slot.
Feb 12, 2008 | Navman PiN 570 GPS Receiver
Navman PiN 570 GPS Receiver Logo
288 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
