Sound and image discrepancy
When watching TV it seems the sound is out of tune from the image. It's a brand new TV with integrated digital so I'm thinking the TV is not in working order. Should I return it to the seller or can I do something about it? Many thanks.
  • 8,617 Answers
I would try to return it to where you purchased it. Most retailers will honor exchanges even if they dont honor a refund.
Posted on Jan 23, 2008
TV went dark no vision but do have sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 07, 2016 | RCA Lg 42ls5700 42" 1080p Flat Panel...
There is sound but no picture. No backlights but can see a picture in dark with flashlight test. LED panel # is D460D3-6Y43-COX. What part would I need to purchase? T
You have check the power supply first .To know how to check the power supply watch the following video. Normally led tvs power supply contains the led drive circuit too. Bot are integrated in the same board. The led drives circuit should have between 30 to 120 volts from the power section depending up on the brand and model number of the TV. If the the voltage is ok then you have problem with the Led driver section section. Either you can try to repair it or can buy a new power board.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 31, 2015 | SEIKI Digital SE46FY10 46" LED TV...
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
Sharp flat tv lc-32sb24u no audio was watching tv last night and the sound just stopped in the middle of a show. picture is perfect. is it worth to fix.
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
Aug 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
How to get TV audio on the FR300 radio?
Your TV band radio won't work anymore now that the US has switched to digital broadcasting. The frequencies now in use aren't the same now, so the radio can't receive them. Plus, the radio doesn't have the circuitry to decode the digital sound even if it could pick up the broadcasts.
Sad to say, you have a radio that now picks up only AM/FM/weather and static. Also, as far as I know, nobody is yet marketing a radio for TV sound with digital capability. All you can do during a power outage is use a new TV with battery capability and digital tuning.
Mar 02, 2010 | Eton FR300 AM/FM/Weather/TV Radio
Crackling noise / loud static when tv is attached to antenna
Pick one:
RFI (Radio Frequency Interference) from nearby electrical/ electronic device.
Antenna misaligned to transmitter.
Antenna coax impedance mismatch.
Faulty connections.
Faulty antenna.
TV tuning.
If the OLD TV worked OK on same antenna it sounds like TV tuning or ANT socket/wiring loose.
Try:
Auto-tune TV with ant plugged in.
Get TVF (TV fundi) or friend to help align antenna.
Maybe a large bird sat on it.
Check coax for sunburn / deterioration. Renew if XX.
Oct 11, 2017 | Televison & Video
No Sound
Maybe a vacant channel or input is tuned.
• If watching VCR (connected only through antenna input), make sure TV is tuned to channel 3 or 4 – same as CH3/4
switch on VCR. Also check to make sure the TV/VCR button on the VCR is in the correct “mode.”
• Simultaneously press the POWER and CHANNEL DOWN buttons on the front panel to reset the TV.
HOPE THIS WILL HELP YOU.. GOODLUCK
Jan 29, 2008 | RCA P61310 TV
Swaping pip images
you need to check your cables. what brand of tv are you using?
Nov 28, 2007 | Sony KP-53V90 53" Rear Projection...
Samsung 42in rear prejection tv
If your remote is not a universal then you will have to take down the remote and clean it probly it is clogged with dirt.if that does not work then you will have to replace the remote.good luck.
Apr 12, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
