Question about Zanussi F1045W Front Load Washer
FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
Is there an adjustment on da zanusssi model no f1045w front load washing machine for the new belt and if so were is it located ? thanks from a desperate housewife
  • Anonymous Aug 16, 2008
    jf1296
  • 126 Answers
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Posted on Jan 23, 2008
6ya staff
SOURCE:
Zunussi F1045W. Horrible noise from the drum when spinning. I think the bearings are ok and the 2 top springs are intact and on. Any ideas? Steve
Hey dude ..... the first opinion may be your problem, the drum is suspended purely with bearings fixed at the rear. If you truely believe its ok - remove the belt & run the machine perhaps the motor bearings is the only other suspect.
At low revs its difficult to ascertain if a beraings faulty or not.. turn the drum by hand and try listen to & compare for noises.
hope you have some luck...
Jul 08, 2011 | Zanussi F1045W Front Load Washer
My Zanussi nexus fl881 wont spin. Can you tell me how old this washing machine is and how to fix/whether to get new one?
6/8 years old.....Souynds like new motor brush kit needed. price of parts about £30. plus labour possible 30 mins work to fit..Hope this helps
Apr 01, 2011 | Zanussi F1045W Front Load Washer
Washing curtians
Select a delicate or wool programme, this will give you a cool wash and a slow spin.
Feb 03, 2010 | Zanussi F1045W Front Load Washer
Machine will not drain
Hi..
If your machine does not drain you need to check this
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Before testing the lid switch, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
Regards
PCmania
Jul 11, 2009 | Zanussi F1045W Front Load Washer
Belt broken on my wdt1085 washing machine.
take off back plate to washer, wrap belt round motor and spider (6 legged wheel above the motor) and turn the spider thats it
Jun 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi Aqualux washing machine
the belt is a tight fit so you need some strength
remove top. loop belt over the motor pulley and start belt onto drum pulley. turn drum pulley and belt will work its way on. there is just enough room to do this
Oct 08, 2008 | Zanussi F1045W Front Load Washer
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Jul 20, 2008 | Zanussi F1045W Front Load Washer
Zanussi F1045W Front Load Washer Logo
264 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
jimorris77
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
