Wireless on targa traveller netbook doesnt detect any available networks
There could be a problem with the driver for the adapter or the hardware itself. The first thing I would try is go into the control panel and then into the device manager. Then look for the wireless adapter and remove it. Then re-boot the computer and windows should detect the adapter and re-install the drivers. If that does not work you could also try and locate the updated drivers from the manufacturers website and install those. Also remeber that it may be a simple as you have turned the adapter off. Netbooks usually have either a switch or FN key and another key combination to turn the adapter on and off. So look on the netbook for a wireless switch or one of the function keys might have a antenna symbol above it. If you find one then try holding the FN key and press the function key....that will trun the wireless back on.
