Question about Nokia 6600
How to remove bluetooth from nokia mother board for 6600
    President:
  • 1,257 Answers
I won't suggest you to remove the bluetooth..All you can do is switch it off..
Removing can damage it
Posted on Nov 15, 2008
    Sniper:
  • 111 Answers
One method i know that will not affect or damage the other parts is by using a sharp thin blade and a soldering rod...solder the side of the side of the bluetooth while inserting the blade so that the lead won't stick to the board again..do this carefully and slowly ensuring that all the lead won't stick back together again..it's a safer way because it won't the damage the UEM which is directly on the opposite side of the board
Posted on Jan 28, 2008
    Guru:
  • 167 Answers
You need the following
tools and material
Need a Hot air device'
twezzer'
flux
dismantle the unit and put the flux around the bluetooth,
re-heat the bluetooth w/ the hot air device or a infared soldering device' wait unti the solder led around the bluetooth is soldered...
Posted on Jan 23, 2008
6ya staff
SOURCE:
Nokia 6600: Bluetooth wont open
solution for 6600 bluetooth and gallery cannot open
step 1) make a jumper (you can see the encircle terminal of bluetooth ic) then assemble the mobile,turn it onstep 2) OPEN FIRST THE GALLERY WITHOUT MEMORY CARD,THEN OPEN ALL THE IMAGES,MUSIC ETC. INSIDE OF YOUR GALLERYstep 3) TIME TO TURN ON YOUR BLUETOOTHstep 4) PUT BACK THE MEMORY CARD AND DO 2 AND 3step 5) then remove the jumper and do step 2,3,4..if still the cannot open again,put the jumper and reheat the bluetooth ic and repeat it step 1,2,3,4.I ..GOOD LUCK TO ALL WANT TO TRY! JUST TRY IT THERE IS NO RISk
Mar 17, 2011 | Nokia 6600
Friends my nokia 6600 problem is:- my file mngr and bluetooth is not open. internet not working
I think you can remove the memory card and battery off the set for about an hour. Now check your card for any errors, have it scanned inthe PC, if there are faulty files remove them off. Now place the battery back and check , if the set boots up but does not show up the file manager/ bluetooth, then you might have to reload the software of the phone. Recommend the services of Nokia care.
Oct 29, 2010 | Nokia 6600
Bluetooth nokia 6600
the firmware on the phone needs to be reflash in the phone.....so take the phone to a mobile repair center and have it done.
Dec 26, 2008 | Nokia 6600
Nokia 6600 Bluetooth, gallery problem.
yez.,, its a hardware problem, you just have to replace the bluetooth module of your phone, or go to a near repair cellshop and ask them to do that,, when you open gallery it only stuck up on opening and when u use your camera, it says temporary overload ryt?? and some application won't work, the only thing is to replace the bluetooth module of your phone
Aug 24, 2008 | Nokia 6600
Nokia 6600 prob
my phone do not shows network actually but sometimes it shows full and goes on decresing and be nil
Jun 08, 2008 | Nokia 6600
"temporary overload", NOKIA 6600
When I open gallery in my Nokia 6600, phone hangs-up. When I use camera, the message "temporary overload" appears. The phone drains out power in a half day.
Dec 23, 2007 | Nokia 6600
Nokia 6600 multimedia problem
The problem of your unit is not easy,you need a qualified technician to open your unit coz the bluetooth module is defective you need to replace it,and prepare some amount for it.....
Oct 23, 2007 | Nokia 6600
Bluetooth problem in my nokia 6600 phone
It's ok if there is no add. Try to relocate an another bluetooth device the add will come automaticaly.
May 05, 2007 | Nokia 6600
Opening problem of gallary in my nokia 6600 phone
This is the problem due to blue tooth. If he bluetooth chip is damaged the gallery is not opened.you opened the set carefully and heat the blue tooth chip. This is the normal procedure
Mar 17, 2007 | Nokia 6600
Nokia 6600 Logo
95 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
