Question about Canon PIXMA iP4200 InkJet Photo Printer
Chip mix up
Is there any way to identify which chip belongs to which colour
    Sniper:
  • 60 Answers
No, it isn't, but you have not so many posibillities in trying to permute them. There are just 24 combinations possible, even fewer if you now the posision of black.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Why is my printer not printing right
This sounds like the chip on the ink cartrige, try cleaning the chip or replacing the red magenta ink. How a printer works, information from the Dynamic Link Libary is sent to the printer driver, this information is where to print on the paper and what colour to print, ie turning the ink jets on and off, the depth of colour comes from each ink by mixing the inks from the information in the photo or text. All ink problems are usually from ink faults, miss printing comes from driver information. Phill
Jan 15, 2013 | HP PhotoSmart Office Equipment & Supplies
My epson rx650 ink pad replacement.
Epson have there reset's pretty locked up, Agents have to register to gain axcess rights to software program tool that resets purge counter (waste count rset) , there are 7 pads in these printers just felt blocks that suck up ink and the electronic counter. all colours are mixed in felt so no draining guess you could wash them out but it is the counter that will stop you, wont go till reset. I have seen some after market ink chip resets but dont know if they work.
Epson about 6 months ago sealed up their tec support download system, now we have to identify agent and rep who is downloading the "eagle" software that is the Epson adj software that allows adjustment and reset of waste ink counter.
reseter link and another http://www.printercartridges.com.au/
Dec 06, 2007 | Epson Stylus RX650 All-In-One Printer
RED COLOUR MIX IN EVERY COLOUR
Provide brand and model number and a photo of what screen looks like.
Dec 03, 2012 | Televison & Video
Hi, i have automatic passat 1999 model and recently water happens to get into the gear box and it control board, i experiences a boom sound anytime the gear is changed, the oil has been changed by the...
If no external leak and the transmission fluid colour looks white, the problem belongs to the automatic gearbox oil cooler. The oil cooler has broke mixing the gearbox oil and coolant causing this milkshake. It's a small radiator core type oil / water heat exchanger. It is cracked inside and transmission oil is mixed with engine coolant. Because the transmission oil pressure is greater than engine coolant pressure, the transmission fluid level drops. See also the coolant colour inside recovery coolant reservoir inder bonnet! It could be like this:
The automatic gearbox oil cooler type oil / water heat exchanger (oil cooler):
In the picture above the transmission oil pan was removed for oil filter replacement.
May 05, 2011 | 1999 Volkswagen Passat
Transmission fluid level need regular top up and there is no external leak.Fluid color looks white.
(In the picture above the transmission oil pan was removed for oil filter replacement).
Oct 29, 2010 | 2005 Audi A4
No wiring diagram for radio/cassette
If you identify the MAKE of existing radio , then you can work out which wire belongs to which cnnection somewhere on this site
.http://www.tehnomagazin.com/Auto-radio-car-connector/NISSAN-Car-Radio-Wiring-Connector.htm
Nov 08, 2009 | Car Audio & Video
All the colours are jumbled up
It looks like you colorwheel is getting defective, i recommend you replace it, just make sure you identify igf it's the one with the silver or gold bearing, because if you get the wrong one, it won't work on your Tv.
Jun 29, 2009 | Samsung HC-P4241W 42" Rear Projection...
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
22 people viewed this question
Clive
Clive
old marine
old marine
Ekse
