Apple iPhone 3G Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i as playings a game and i must of press something and now all my icons and everything are large how do i get them back to normal size
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Dec 19, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
8789
Points
142
Well start by switching your phone off and on again if that don't work then try keeping it the way it is
Menu icon on screen can't reduce to normal
Simply use 3 fingers to double-tap on your iPod's screen to put everything back to their normal sizes.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
Any game i play disk arcade or demos xbox freezes
Try the following:
  1. Hold disc by the edges without touching the surface with your fingers. Clean the disc with a soft cloth, lightly wiping from the center outwards. Do not use solvents or chemicals to clean the disc. Examine the disc for any visible signs of damage.
  2. Verify whether the Xbox console clock is set correctly.
    • Turn on the Xbox console without a disc in the drive.
    • Press the directional pad up or down to select Main Menu, and then press A.
    • Press the directional pad up or down to select Settings, and then press A.
    • Press the directional pad up or down to select Clock, and then press A.
    You can see the date and time from this screen. Correct the date and time as neccessary.
  3. Try to play the game again. If this does not work, you can try to clear the game cache on the Xbox hard disk. If you have a Xbox Memory Unit available, copy the game cache for this game from the Xbox hard disk to a memory unit:
    1. Insert a memory unit into a controller connected to your Xbox console.
    2. Open the disc tray and remove any disc, if present.
    3. Close the disc tray and re-start your Xbox console.
    4. Select Memory from the main Xbox Dashboard, and then press the A button.
    5. Select Xbox Hard Disk, and then press the A button.
    6. Locate and select the game you want to back up in the list of games.
    7. Select the appropriate save game icon. The Save game icons are located to the right of the game icon. Each save game is identified with a name, date, time, and size.
    8. Press the A button to display the Copy/Delete menu for the save game.
      Note: If Copy is not available, you have not chosen a save game file.
    9. Select Save, and then press the A button.
    10. Press the A button again to save to the appropriate memory unit.
    11. As soon as the copy is complete, press the B button to return to the list of save games.
    12. Repeat these steps as needed to back up your other saved games for this game.
    If you do not have a memory unit, deleting the game cache removes your progress in the game, high scores, and other information. To find the game cache, follow these steps:
    1. Open the disc tray and remove the any disk, if present.
    2. Close the disc tray and re-start your Xbox console.
    3. Select the Memory option from the Dashboard.
    4. Select the Xbox Hard Disk.
    5. Locate and select the game in the list of games.
  4. Select the large game icon to the left of the list and press the A button.
  5. Press the Abutton again to delete the game cache file.
    Note: Delete should be the only available option. If Copy is available, you have chosen a game save file and not the game cache file. Press the B button to return to the list, and then select the leftmost icon.
  6. Select Yes to permanently delete the game cache, and then press the A button.
  7. Confirm that the icon is no longer listed, and then re-start your Xbox console.
  8. Insert the game disc, and then either load your latest saved game from the memory unit, or play the game from the beginning.
4helpful
2answers
Icons on computer are very large after closing a program; restart doesn't fix
Yes, it is normal because your game is running in a lower resolution. When the game is exited properly, then your normal resolution is restored but since it didn't exit properly, it forgot to change your resolution back.
Assuming this is windows xp, right click anywhere on the desktop that does not have an icon and select properties. There you can change the resolution to what it was; since I don't know what it was, you'll have to test a few to see which one looks the way it did before. Then once you find it, press okay and it will save.
Hannspree 19" HF199H LCD - Display is LARGE on monitor!
Try Control Panel - Appearance or Display- You can change how your 2nd display looks there.. Sounds like you have it set in Clone mode...(both displays show the same things)...See if you can reset the 2nd display resolution while keeping the laptop in its normal resolution. Not all machines can do this...but most recent ones should be able to.
7helpful
Monitor is enlarged, wont return to normal size
You may have hit the "F11" key which takes the open window to fullscreen. "F11" toggles large, small... If not that, beboot. If that doesn't clear it up, then the display settings have gotten altered. Right click on the desktop, select "settings" and increase the resolution. Windows should prompt you to keep or reject the change. Select yes or no when prompted.
1helpful
Everything on my computer is huge
You've right clicked and tried setting it to the right resolution ?
Tried updating the video drivers ?
When ive played a game on my hp 6000 and ive finished and returned back to normal use. It seems as though the graphics on the internet pages are distorted, somewhat bigger than they were before i played...
dear,
doent matter what the icon size ur using normally. i vedio game there it has its own resolution size in Vedio setting/graphic setting. when u go to play the game, the game mode will be changed according to the internal game setting, and when u quits then it will come back to its original setting.
2ndly, u talked about the game on ur hp6000. what ur system contains:
its depend upon the VGA card capacity and ur ram too.
u can check what is causing problem in the requirements of the game Readme file .
check and confirm the requirements there
regards,
hope u will rate it.
3answers
Large icons
hi, goto desktop properties, settings, advanced, there in general tab, change the DPI settings to Normal size(96 dpi) and click OK, and restart.
If this did not work let me know.
Hi, three possible things. 1) You have activated the magnifier. Go to Start, All Programs, Accessories, Accessibility, Magnifier - deactivate, should be a small window bottom left of the desktop. or 2) Your screen resolution somehow changed. Right click on any clear part of the desktop, go to properties, Settings Tab. Adjust screen resolution to desired setting then click Apply/OK. or 3)You are in Safemode. Restart and if same large icons etc, do # 2. Hope that this be of some help to you. Pls post how things turn up. Regards
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
