Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
About my pc's configuration
I want latest & high-tech configuration of processor,motherboard,memory,videocard etc.
  • Ryan Trumbull
    Ryan Trumbull May 11, 2010
    Most people have a preference.. AMD or Intel?
    Genius:
  • 1,067 Answers
Amd i live get amd x 6400 with 4 gb ram to start nice asus mobo and a 8800gtx video nice power suply with it and mide size case with alot fans ok u can pplay any game get parts on newegg.com all for under 500
Posted on Jan 25, 2008
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Sep 12, 2010 | Acer Aspire M1640 Refurbished Intel...
Please show much higher compatible microprocessors
As per my concern if u want to replace & ugrade all the parts then u take a NVIDIA motherboard only because , the fx5500 videocard is of NVIDIA geforce company only thats why it will suit the motherboard itself & also nvidia provides 256MB onboard videocard so if u keep fx5500 videocard free it will be all right
Let me know is this helpful to u or not
Jul 05, 2010 | Asrock K7VM2 Motherboard
When I start up my PC there is an error no signal i cannot start the PC i hve tried replacing the memory and also the videocard. but it doesnt work.. whats the problem ?
no signal means either lead to monitor loose or adrift..contacts on memory dirty,the processor not kicking in,try resetting the bios button on motherboard,on some motherboard theres a lcd readout which shows a code if any problems
Jul 05, 2010 | Acer Aspire M1641-U1521A PC Desktop
Pc reboot ramdomly or freeze after a while
HI! THE ONE QUESTION I NEED TO KNOW IS WHAT OS? JUST GENERALLY I WOULD SAY THAT YOU MIGHT TRY TO UPDATE THE OS TO THE LATEST VERSION. AGAIN, NOT KNOWING THE OS, THIS IS A FIX I WOULD TRY. YOU SAID THE PROBLEM HAPPENED AFTER YOU INSTALLED THE OS, BUT WHAT ELSE WAS INSTALLED ALSO? YOU MIGHT NEED TO LOOK AT ALL PROGRAMS TO BE SURE THAT YOU HAVE THE LATEST VERSIONS AND THAT THEY ARE COMPATIBLE WITH YOUR OS. SO, THESE ARE SOME IDEAS FOR NOW. TRY THEM AND IF NO LUCK, REPLY AND LET ME KNOW THE OS YOU ARE USING AND THE PROGRAMS INSTALLED. OK? I'LL BE GLAD TO HELP.
ARCLIGHT1217
Nov 02, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Joey64,. pno ko nman mla2man kung ang anu clock speed ng pc ko? tska kung anu compatible na memory and videocard. P3 733 is my pc.
733 is the processor. thats determining the speed of your system. compatible memory is SDRAM 256 mb, AGP video card geforce 1-4.
sana ok na sayo.
bakit di ka mag upgrade ng PC. marami namang mura dyan 16T ok na.
Jan 10, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
VGA1 video adapter problem
I have M748LMRT motherboard which has Xcel2000 chipset. I want to know pinouts of ATX header J3
Dec 27, 2007 | Pc Ware M748LMRT Motherboard
Can't istall xp
check your ram memory, the winxp must have at least 128mb ram memory and a videocard with at least 32mb. if you have these your pc will boot with no problem
Oct 23, 2007 | Intel Motherboard
PNY geforce 6600 ddr 256mb agp/ with Asrock k7s41 motherboard When i install PNY geforce 6600, sis 741 chip on mobo seem to be still running. have changed to AGP from PCI in bios, card will...
PSU 250W usually isn`t good with GF6600 (like and high) videocards. Strongly recommended 350W and high for this configuration (and "350W" - not only numbers in model - for really QUALITY PSUs).
Sep 25, 2007 | Asrock K7S41 Motherboard
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
