Question about Motorola Mobility RAZR V3
Problem with Data cable
When i connect my V3 with laptop through data cable, it does'nt recognize and gives the msg 'One of the device connected with USB has malfunctioned'. I have checked the USB port with other devices and its working. the input of cell phone is also working as the phone charger is connected with the same port and it charges perfectly.
Quisiera que me ayudaran a desbloquearle el imei a mi tlf un v3 blak
Posted on Jan 23, 2008
External hard drive data recovery
data recovery services are the best possible option for you to recover all the data.
check http://bit.ly/1ve3b8v
Apr 18, 2015 | Hard Computers & Internet
Purchased a maxi n.u and we are having trouble connecting the device to a NT O/S DRIVEN PC. We have connected the disk via aUSB CABLE . We have tried to get the Mass Storage Drivers from their Website but...
from trekstor's web
  • Communication with the PC
  • list.gifSuitable for new Windows® Vista
  • list.gifSuitable for Windows® 2000, XP, Vista, Mac® OS X, Linux® from Kernel 2.6.x
  • list.gifExtremely fast data transfer from Hi-Speed USB 2.0 connection (compatible with USB 1.1)
  • list.gifPreformatted, immediately operable without driver
Sep 24, 2008 | Computers & Internet
Not connected to internet via data cable
do you have the installer for your phone? if you have, try these steps..
1. restart your pc (to make it fresh,and hereby erasing some problems created during your cable connection)
2. install the software for your phone model(make sure it is compatible to your operating system)
3. connect the usb data cable, let it install automatically first.
>>if it didn't install and resulted to the same issue,
repeat step no 1, 2 and 3, but this time, don't let install automatically,instead..
1. open your device manager
2. look for your usb data cable.
3. update driver.
4. uncheck the look for the best driver automatically
5. check the box for ''include the driver in this location''
6. browse where you installed your software, preferably it goes to c drive, program files.
7. check if it will install..
Feb 21, 2010 | Nokia 5130 Cellular Phone
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Feb 25, 2009 | Canon PowerShot SD1000 Digital Camera
Dku-5 data cable problemm
then it must be a data cable problem ,u should see whether this is a correct cable that u connect if this is nt go for a new one
Oct 16, 2008 | Nokia 6610
Can not access my hard disk
It would be a good idea to run a anti spyware and anti virus to check the drive.
Thanks
Aug 22, 2008 | Computers & Internet
Motorola l6 connect to pc usng usb (no mobile phone tools cd)
It is possible that you have a bad data chord. Recently I have come across several data chords that will not acknowledge the v3 cell phone I was trying to use with my Motorola Tools program. I tried a different data cable and it worked without any problems. If you don't have a 2nd data cable you might ask friends and family if they have one you can borrow so you can verify if it is the data cable or not. If you find that it is the data cable you could then purchase another one.
Jul 25, 2008 | Motorola Mobility RAZR V3
The pc does not recognize moto v3 when connected through USB cable
good day, try using motorola pc suit. you can download it at motorola web site. tnx
Jan 29, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
