Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
UNABLE TO OPEN GROUP POLICY EDITOR
Whenever I try to open Group policy editor by typing "GPEDIT.MSC" in run I get a window saying
snap in failed to initalize,
Name:Group policy object editor
CLSID:{8FC0B734-A0E1-11D1-A7D3-0000F87571E3}
Assist me to solve the problem.
  • Anonymous Feb 13, 2008
    gpedit.msc
  • 50 Answers
I'd suggest downloading and installing the Server 2003 Administration Tools. There were updates to several over the course of the last two service packs and may fix your problem. They are downloadable via http://www.microsoft.com/downloads. Do a search for Administration tools or adminpak.msi
Posted on Jan 23, 2008
How to fix access denaid probems.
Open the Local Group Policy Editor Applies To: Windows 7, Windows 8, Windows Server 2008 R2, Windows Server 2012
You can open the Local Group Policy Editor by using the command line or by using the Microsoft Management Console (MMC).
To open the Local Group Policy Editor from the command line
  • Click Start , type gpedit.msc in the Start Search box, and then press ENTER .
To open the Local Group Policy Editor as an MMC snap-in
  1. Open MMC. (Click Start , click in the Start Search box, type mmc , and then press ENTER .)
  2. On the File menu, click Add/Remove Snap-in .
  3. In the Add or Remove Snap-ins dialog box, click Group Policy Object Editor , and then click Add .
  4. In the Select Group Policy Object dialog box, click Browse .
  5. Click This computer to edit the Local Group Policy object, or click Users to edit Administrator, Non-Administrator, or per-user Local Group Policy objects.
  6. Click Finish .
Jan 28, 2016 | Computers & Internet
Tip
Running maintenance tasks while logging on and off
The tool you need to use is the group editor ,which is a part of the win xp and vista .In Xp start the group policy editor by clicking start >run >and type gpedit.msc .To Run a script when a user is logging on or off select local computer policy < user configuration > <windows settings > <script (log on ,log off) in the tree structure in the left pane of group policy editor window.In the right pane ,you will see icons for, log on & Log off .If you wish to run your own script when user is logging off ,double click,log offf or double click log on to run a script at startup .the following steps are same in both the cases .
in the following dialog click"show file ".windows explorer then shows a folder into which you can copy and paste the script to be run. script that suppose to be run by the operating system when a new user log off are in the folder "system 32\grouppolicy\user\scripts\logoff" .the script to be run when a user logs on in the "system 32\group policy \user\scripts\logon" folder .
As soon as the scripts are in the respective folder ,click "Add ".then select the script file "browse' in "script parameter",enter any parameter that are required .confirm with "ok".then selected scripts apperars in the list "log off properties or "log on properties" dialabox to run more than one script ,add all other needed files to the list one after the other "Add" .With "edit",you can change an already listed script or delete files from the list using "remove".the Sequence each one is executed in can be adjusted "Upwards" and "downwards".Then click "ok" and close group policy editor .windows now automatically runs the specified scripts while logging on or logging off .contrary to the "auto starts "folder that exits for every user account ,the changes described here effect all users .Therefore ,make sure while programming the scripts that they are to be run for all users
on Apr 24, 2010 | Computers & Internet
Tip
How to Enable Task Manager in Windows XP
Method 1
  • Click Start, Run and type Regedit.exe
  • Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  • In the right-pane, delete the value named DisableTaskMgr
  • Close Regedit.exe
Method 2: Using Group Policy Editor - for Windows XP Professional
  • Click Start, Run, type gpedit.msc and click OK.
  • Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
  • Double-click the Remove Task Manager option.
  • Set the policy to Not Configured.
on Dec 08, 2009 | Computers & Internet
How to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
Cannot enable sytems restore. Message: Group
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
* Delete the value DisableConfig
* Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
More Information
Turn off System Restore corresponds to DisableSR registry value. With this Policy is turned ON, the System Restore tab may be missing in My Computer Properties. Also, when you run System Restore (rstrui.exe), you receive this message:
System Restore has been turned off by group policy. To turn on System Restore, contact your domain Administrator.
Turn off Configuration corresponds to DisableConfig registry value. With this Policy turned ON, the System Restore tab will remain displayed but the user cannot configure the SR options. It reads disabled by Group Policy.
http://windowsxp.mvps.org/srpolicy.htm
Or perhaps you can review this
Control of System Restore function has been disabled by "Group Policy".
How do regain control?Go to Start>Run, key in gpedit.msc and hit ENTER. Under Computer
Configuration, expand Administrative Templates, expand System, then click on
the System Restore folder. In the right-hand pane, double-click on Turn off
Configuration and, under the Setting tab, click in the radio button beside
Not Configured. Click on Apply then OK.
Please visit the following Microsoft Knowledge Base website
and review the topic titled: "Method 1: Use Group Policy".
How to Disable the System Restore Configuration User Interface
http://support.microsoft.com/default.asp…
Note: You must be an administrator or owner, or have administrative
privileges to perform this task.
Undo the changes using Group Policy Editor (Gpedit.msc)
-or-
Open Registry Editor and navigate to:
HKEY LOCAL MACHINE\SOFTWARE\Policies\Microsoft\Wind… NT\SystemRestore
In the right-pane, delete the value "DisableConfig".
Close Registry Editor
Close and re-open the System Restore properties page.
Note: Group Policy Editor is only Available in XP Professional (according to http://www.pcreview.co.uk/forums/thread-…
Perhaps one of these links will give you the correct solution
http://forums.techguy.org/windows-nt-200…
http://www.winhelponline.com/blog/restor…
http://www.computing.net/answers/windows…
I hope this helps you to resolve your problem.
Jan 03, 2010 | Microsoft Windows XP Home Edition
System restore has been turned off by group policy
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
---> System
Nov 24, 2009 | HP Pavilion dv1000 Notebook
My system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
In the right-pane:
---> System
For standalone Windows Vista systems, use these steps:
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
I am not work with my gpedit.msc
Unfortunately Windows XP Home edition does not have group policy editor and can not connect to a domain. You will need to upgrade to XP pro in order to have this functionality.
Jun 11, 2009 | Microsoft Windows XP Home Edition
Want to unable Autoplay option
go to start menu then u see run.
type in run "gpedit.msc"
then enter and u can see group policy editor.
then go to user configuration -administrative templates - system then u can find in right window
"turn off autoplay" doubler cl kit and disable it.
Jun 02, 2009 | Microsoft Windows XP Professional SP2
Disabled task manager
1. Verity that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
"Task Manager".
1.1 "Local Group Policy"
a. Go to "Start" -> "Run" -> Write "Gpedit.msc" and press on "Enter" button.
b. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
c. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
d. Close "Gpedit.msc" MMC.
e. Go to "Start" -> "Run" -> Write "gpupdate /force" and press on "Enter" button.
Note: If you are using Windows 2000, please follow KB q227302 instead stage "e".
Using SECEDIT to Force a Group Policy Refresh Immediately
http://support.microsoft.com/kb/q227302/
1.2 "Domain Group Policy"
a. Contact you local IT support team.
2. Verity correct registry settings::
a. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
Warning: Modifying your registry can cause serious problems that may require you to reinstall your operating system.
Always backup your files before doing this registry hack.
b. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
c. Reboot the computer.
May 23, 2009 | Microsoft Windows XP Professional SP2
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
952 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
