Question about Garmin GPS 48 GPS Receiver
Garmin GPS 45
Hi
The GPS unit i have turns its self off after 5-10 mins and will not pick up any satellites.what would cause this?
  • Anonymous Mar 29, 2008
    The GPS 45 will not pick up any satellites.
    where download new software for update gps 45.
    Novelist:
  • 113 Answers
It is probably one of the following:
1)Old Software
In 1999 the GPS satellites were reset and the new almanac data had to be loaded into the GPS 45 for it to continue to work. It was not uncommon for that model to quicly kill a set of batteries when it is having difficulty acquiring, which would cause it to shut down in order to save the batteries for its internal memory.
I just did a quick search of the Garmin website and it appears they no longer support that model. If you go to their support page and send a request for a software update they can probably e mail it to you. The update is free but to down load it, you need a PC interface cable (RS232 serial port connector) Part Number: 010-10141-00 Suggested Retail Price: $ 38.09.
2)Bad antenna
To rule this one out, borrow an antenna from another Garmin 45 or Garmin 48, or plug the unit into an external antenna and see if the unit still shuts down. The drawback to this method is that you can buy a new GPS that is superior to the one you have for about the same price as an external antenna.
3)Bad batteries
If your batteries are low, the unit will automatically shut off to protect its internal memory. I tried a lot of different batteries in my 45 and I found that Eveready alkaline batteries worked best. Rechargeable nicad batteries don't work very well because they fool the battery meter. Newer models have a setting to specify that you are using rechargeable batteries.
Ultimately the best advice I can give you is buy a new GPS. For less than $150 you can buy a new model that is more accurate, more reliable, stores more waypoints, has a better display, is easier to use, and gives you more valuable information.
Please rate this information as helpful.
Posted on Jan 24, 2008
My garmin GPS 12 will not pick up and lock on the satilites
Go to the Garmin website and download up to date software for your unit. A new satellite launched in '08 caused some problems, and the update fixes this.
Please come back and let us know if this fixes it.
Dec 20, 2009 | Garmin GPS 12 GPS Receiver
Garmin Nuvi 1300 couldn't reach satellite!
THERE ARE A NUMBER OF SOFTWARE UPDATES IN THE LAST FEW MONTHS CAUSING PROBLEMS GO TO WWW.GARMIN.COM/SUPPORT
DOWN LOAD NEW SOFTWARE UPDATES
Dec 12, 2009 | Garmin nuvi 1300 Car GPS Receiver
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Battery replacement now ca't find satellite Garmin c320
I had the same issue with the only difference that I haven't replaced the battery yet. When my unit can't locate or acquire satellites I change between GPS and WAAS mode. Within 45 seconds my unit successfully locates satellite. After some time if I disconnect unit I might have to switch it back to GPS and so on, and so on, and so on. It worked for me for past 3 months... Hope it will help you...
Nov 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Etrex Legend crashes after about 3 min
Update your unit software for free via the Garmin.com website. This is caused by a new satellite launched in 2008. The update fixes this problem.
Sep 29, 2008 | Garmin Nuvi 350 Car GPS Receiver
I have a Nuvi 200w that I received last December as a gift. This unit takes forever to aquire a satellite. The "DIFFICULY AQUIRING SATELLITES" message comes on 90% of the times I try to use it....
While under warranty.... yes.... Make sure it's been registered on their site before calling them and requesting an RMA number.
- Jim
Sep 17, 2008 | Garmin GPS
GARMIN DOESNT PICK UP SATELLITES
You have a problem with your internal antenna. You can easly reslove this by hooking up an external antenna, and watch it go from 20 to two mins.
Feb 09, 2008 | Garmin StreetPilot c340 GPS Receiver
Can't get satellite fix
Keep in mind that GPS uses "Line Of Sight" for success.... in other words, the unit satellite antenna needs to pick up 3-6 GPS sats in ourder to determine one's lat/long position. Make sure the antenna is clearly visable to the sky.
If this is not the issue... Warranty replacement may be the only option where you bought it.
Feb 07, 2008 | Garmin Nuvi 660 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
My Garmin has stopped finding destinations - just says "Searching for Satellite)+
I had the same problem with my Nuvi 310. Found a solution in here that works. Here's a copy of the advice.....note you will need to get in the car and set it for a destination and go. 5-10 mins later the Garmin Nuvi will lose the satellites, but don't adjust it it, leave it on and keep going. Eventually after about an hour it will right itself, pick up the satellites and evrything will be back to normal.
Here's the advice:
happy2surf
Rank: Apprentice
Rating: 81%, 49 votes
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching!
The unit appeared to have "stuck" in this acquiring mode. The following worked for me:
1) open the GPS antenna
2) press the bottom left screen while holding the power button to turn the unit on
3) enter maintenace mode
4) select diagnostics
5) clear error report, do NOT clear any user data
6) restart unit the usual way
My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Dec 05, 2007 | Garmin nuvi 350 GPS Receiver
Open Questions:
"Upload ...Not Present" message. Nothing else on the screen. I replaced the internal battery last spring used it all summer. Have just checked internal and external batteries and all are fresh 3v internal and new AA four batteries. Upon startup the screen says "Upload" "Not Present" and there is no menu. I have tried hitting Page and Menu, etc. nothing happens. I tried leaving it out and on for 3 hours to see if it would find itself and satellites. I tried connecting to the computer and uploading the internal program the port was not found. Tried this a number of times and a number of ways. I have tried leaving it on to search for 3 hours and have tried to connect to my computer to reinstall the software but that does not work. The internal battery was replaced with a new one last year. I have fresh batteries in the unit. What is the problem? How do I fix it? Thank you. I love this unit and would like to keep it going. I have fixed two others for friends who needed the internal battery fixed. They use it as a backup. I have tried the Auto Locate procedure about 3 times. I have also tried clearing by holding the PAGE + Power. Then tried autolocate. Message "Upload... Not Present" still remains. Also have tried clearing by holding the MARK + Power. Then tried autolocate. Message "Upload... Not Present" still remains. Now I am wondering if this message has to do with an interrupted connection with EasyGPS from last winter. I was uploading waypoints, and thought it had completed and may have turned off and disconnected the plug before an operation was completed in saving waypoints off the Garmin 48. I do not know this for a fact, but that was the last operation I recall doing last fall, before starting the GPS up again on the boat this spring. I have also tried to connect the unit to Easy GPS via the serial port, thinking perhaps it would complete whatever it is trying to do. I have tried uploading routes and downloading routes via EasyGPS send and recieve and it does not seem to work. I wonder now if the interface setting has been reset, by my pressing PAGE+power and Mark + Power earlier. I would not mind that if the menus came up properly, but that is not happening. Is there some other way to kick it out of this mode? I turn it on and there is the message "Upload...Not present" and none of the menu buttons work to get it into the normal startup screen mode..... I've tried Quit, Page, Enter, Goto, Mark, Power (off and on), and none of the get the computer out of this mode and back into the normal menus for startup. I've removed the antennae and checked all the contacts and that seems fine, and reinstalled. Is there some small reboot button inside that I can jumper? I have tried taking the internal battery out and letting it sit for three days and it still does the same thing. Any suggestions would be appreciated
Jul 08, 2010 | Garmin GPS 48 GPS Receiver
See all Garmin GPS 48 GPS Receiver Questions
Garmin GPS 48 GPS Receiver Logo
1,081 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
