Question about LG KU990 Viewty
Screen I"ve got 3 Jasjar and one of them started to play up yesterday, when i turn the pda on horizontal position the screen is blank and when i flip it to portrait position it works. Please help.
POWER ON i-mate JAMIN PM300 ALIGN SCREEN
Posted on Mar 23, 2008
Just change your screen
Posted on Jan 24, 2008
6ya staff
SOURCE:
Playstation 3 Help!!!
try bowing it out with air seems gpu is getting hot or use vacume to suck all dust out .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Aug 07, 2014 | Sony Playstation 3 (PS3) Console
Monitor viewing position
what model of monitor do you have..?
May 18, 2008 | Philips Brilliance 107B 17" CRT Monitor
Blackberry 9780 white screen
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | Cell Phones
Phone working but screen is black
Software/Virus:
Flex problem
Conclusion
Good luck.
Jan 10, 2012 | HTC HD7 Cell Phone
When playing a game the screen goes blank after a while
Dude, all you have to do is restart your console and it should start up fine. If it doesn't, keep restarting it until it does. The new-age HD cables have to load a lot of **** to and from your TV to display properly, and if it has the smallest delay, it doesn't display ****.
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
I-mate jasjar does not align by tapping on different positions
1st thing to do is that, if you know how to disassemble your jasjar try to align the four connections behind the LCD or try to resolder it. If still not working, 2nd thing to do is you must change your Touch screen sensor. If you know how to change the sensor it's much better but if not, then you have to go to a mobile technician. Hope I help you with my idea on your problem there....
Jul 03, 2008 | i-mate JASJAR Smartphone
Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Apr 26, 2008 | Canon ZR200 Mini DV Digital Camcorder
JWIN DVD player horizontal control
I had this problem and pressed all the keys until I hit the SYSTEM button on the remote control. All was fixed.
May 20, 2007 | Jwin JD-VD135 DVD Player
LG KU990 Viewty Logo
100 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
