Question about HP OfficeJet 7310 All-In-One InkJet Printer
Jam in the document feeder
I have a paper jam deep in the document feeder. HP on line support says this: "WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder."
However, they don't tell you how to lift the pick assembly. The jam is way down in between the feeder, underneath the cover.
  • 2 more comments
  • uvagt Mar 09, 2008
    I think my problem is similar. Need to get below the rollers and remove paper from the automatic feeder. Don't have the screwdriver's you mentioned, but my allen wrench took off the first three screws I encountered.
  • carmgn1919
    carmgn1919 Oct 20, 2012
    The paper was jammed in the faxfeeder...i redialed the number the number(with fax cover off;may not be necessary),but the fax started again tried to fax jammed paper and then came out at the fax feeder exit.I know you are not talking about the fax feeder,but i hope this help someone anyway.
  • Anonymous Mar 14, 2014
    automatic doc feeder pulling paper sideways hp laserjet pro m570dn
  • Anonymous Mar 23, 2014
    The automatic document feeder is taking multiple pages at a time. Then it displays
    "Load Paper, then press the check". How to fix that?
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Posted on Mar 09, 2008
I had paper stuck in the ADF on my L7580 (I think it's the same ADF). I unplugged the printer, removed the ADF frame (blue and clear "window" on the underside of the scanner lid) and stuck something long and thin behind the exposed paper (I used a metal shish kabob - thinner one way for flexibility, then rotated it sideways for less bending). Grab both ends and wiggle it to loosen the paper. I eventually had to tear the page, but one half came out easily and the other half got ejected by the rollers when I powered it on again.
Posted on May 10, 2008
  • 55 Answers
If u really want to do that u need a special screw driver that is called T10,If u have that i can guide u ,n u can do it
Posted on Jan 23, 2008
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
get rid of that hp piece o crust. demand your money back.
Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
Document Feeder, a warning dialog box opens after a few
moments.
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
1,979 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
