Question about Timex 1440 Sports Aggressor 56014 Wrist Watch
Timex 1440 Sports Aggressor: how to set time and alarm
Please, I need help trying to figure out how to set my watch and take of my alarm that has gone off every day for the past 2 years! I've managed to figure out that it is 5 mins behind, but i want to get that 5 mins back.
Please help!!!
  • madknit Feb 07, 2008
    my watch is one hour ahead and I can't figure out how to reset the time
  • kl5429 Dec 03, 2008
    I can't figure out how to turn the alarm off. It goes off daily.
Hold the top 2 buttons until "alarm" no longer appears
Posted on Feb 15, 2008
I just bougth a 30 lap shock/resistant timex ironman triathlon, and i need to know how to use it... i have no instructions thanks
Posted on Feb 06, 2008
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
My son's watch is the 1440 sports model. How do I get the time to switch from 24hr mode to regular 12hr mode? It's driving me crazy!
Thank you for contacting FixYa. <br /> You can find the manual here!<br /> <a href="http://www.timex.com/info/Product_Instruction_Guides_Downloads">http://www.timex.com/info/Product_Instruction_Guides_Downloads</a><br /> Best regards!
Aug 25, 2010 | Timex 1440 Sports Aggressor 56014 Wrist...
How do i get the timex 1440 sports watch military time to change the hour and minutes wont change
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Jul 15, 2010 | Timex 1440 Sports Aggressor 56014 Wrist...
Mid Size Sports 1440 Black Nylon Strap Watch: hi i forgot how to set the time on my timex 1440 s...
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
May 18, 2010 | Timex 1440 Nylon watch
How to set my timex watch
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Dec 11, 2009 | Timex 1440 Sports Aggressor 56014 Wrist...
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Aug 30, 2009 | Timex 1440 Nylon watch
Alarm
On this 1440 watch to cancel the alarm first push the adjust button (bottom right on this watch) this will bring up the alarm time previously set and while still holding the adjust button tap the stop/start button (top right on mine) this should deactivate the alarm
Mar 08, 2009 | Timex 1440 Nylon watch
I have a Timex 1440 sports watch. I have Parkinsons and must take medicine on a specific timed schedule. For a while all was well with this watch; the alarm rang when set. However, I think I inadvertently...
I think you just turned off the alarm. You need to press the MODE button until you are in the alarm mode. (AL or ALARM on screen), then I believe that you just need to click on the upper right hand button (strat/split or stop/reset) repeatedly until the alarm goes back on. Hope this helps.
Dec 29, 2008 | Timex 1440 Nylon watch
How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Jul 12, 2007 | Timex 1440 Sports Aggressor 56014 Wrist...
Timex 1440 Sports Aggressor 56014 Wrist Watch Logo
475 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
