Question about InFocus ScreenPlay 4805 Multimedia Projector
Yello bar i have sp4805, i am already usde the projector almost 1year 8 month now the problem in Yello bar display in right side screen. give me the solution and where i get the spares
This is most likely to be a collapsed light tunnel, see other posts that relate to this problem
Posted on Jan 23, 2008
How do i make my resolution greater on windows 8?
Hi there. To get to the resolution settings on Windows 8, first bring up the 'Charms' bar on the right hand side of the screen (either swipe from the right for touch screen devices, or hover the mouse pointer in the bottom right or top right of the screen for desktop users). When the Charm bar slides out, click on Settings, and at the bottom of this next menu that slides out, click on 'Change PC settings' - this will bring up the Windows 8 Settings menu. Next you'll see a list of options on the left to choose from. Select 'PC and Devices', then select 'Display'. This should give you the resolutions settings to tinker with. :)
Feb 11, 2014 | Computers & Internet
Screen dim lighten
On your Mac...
Click on the Apple icon at the top left of your screen.
Then select System Preferences.
Then select the DISPLAYS icon.
In the displays window, you will should see a Brightness slide bar. Make sure that slider bar is all the way to the right. The the slider bar is already to the right side, then it might be a hardware issue with your Mac. =(
Feb 06, 2014 | Apple Computers & Internet
Computer screen on, Projector off
If you are running Windows 7\8:
Leave the ViewSonic projector on.
Right click anywhere on the desktop and select "Screen Resolution".
In the display column, it will give you an option to select your computer monitor, the ViewSonic, or to clone the displays.
Select your computer monitor display only.
Shut off the ViewSonic projector.
If you are running Windows XP:
The process is basically the same except you find the settings under Control Panel > Display.
Jul 09, 2013 | ViewSonic Office Equipment & Supplies
Projector goes POP!
I think it's the bulb, the best would be to take it to the shop where you bought it - or any other good electronic goods shop - so they can test it. If its still under guarantee its better to take it to the dealer. Mine had to have the bulb replaced after only 8 months, but it was still under guarantee.
Jun 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have SP4805 bulb does not fire up "New"
push and hold both volume up and volume down for 10 seconds.
Mar 03, 2009 | InFocus ScreenPlay 4805 Multimedia...
Dark area on right side of screen, just showed
I am Brasilian and i don't speak english very well, so sory. A friend had the same problem,and other friends too.
The mirrors and the Color Wheel of the Infocus sp4805 are atached with fragility by glue that with the high temperature and humidity deteriorates. The detachment of the color wheel or the mirrors drivers of light produce dark spots. It is easy to solve. Just paste again, but should be done by specialized professional.
Jan 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Infocus SP4805 buzzing noise
Hi dcabbarno
The buzzing noise is a broken colourwheel and the shadow could be a part of the colourwheel that is obstructing the light engine or it could be your packlight pipe ( tunnel with 4 tiny mirrors in it ) that was damaged when the colourwheel broke.
I do unfortunately not have the part numbers of the parts that I mentioned , but you could assist by opening up the unit and supplying me with the part numbers.
The colourwheel you will spot straight away once you've taken off the top cover of the Projector , the packlight pipe is situated right next to it - looks like a small tunnel that's got 4 mirrors inside it - takes the light into the light engine.
Once you've supplied me with these I can get you prices and places to order it from and will help you with instructins on how to replace them - it is quite easy to DIY.
Thanks for using Fixya !
May 14, 2008 | InFocus ScreenPlay 4805 Multimedia...
Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Mar 13, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
100 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
