Question about Intel Motherboard
Video card prob
I am using intel845WN motherborad there is no onboard VGA can i use PCI VGA card if it possible pls tell me the memory range and company name of yhat card
    Sniper:
  • 74 Answers
I serch the web for you and find this..
>> Re: intel mb (D845WN) won't recognize my Geforce4 Ti 4200
I have the same mb, the intel845WN, and I hav a TI4600 from bfg tech too, and it seems that it isn't at its best!
I don't know what is the problem, I'm trying to get it solved with bfg but they stopped answering me. It's hard because I'm in Brazil and I don't have any way of getting the support.
Just by e-mail.
I've tried every driver but it isn't what I've expected.
By the way, I had a gf2 mx200 and it worked just like the ti4600, as good as the ti. Incredible isn't it?
Just try it....... good luck and rate me
Posted on Jan 23, 2008
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
I have a P5GC-MX 1333, I have an nvidia graphics card, but I want to plug a monitor to the nvidia and to the onboard card as well. Once I installed the nvidia graphics card the internal card is not...
Internal video and AGP / PCI Express video cards use the same "pipeline" so you can only use one or the other, not both.
If you need additional video ports, you HAVE to get additional cards / a video card with multiple video ports.
Apr 09, 2010 | ASUS P5LD2-VM Motherboard
I want to use a better vga but it isnt any port
Without a VGA port, you can't use a VGA card, pretty simple stuff.
If you want to add a video card, you will need to get a PCI video card (NOT PCI-E!) There are a number of them out there, and pretty much anything made in the last 3 to 4 years will be better than the on-board video...
Dec 18, 2009 | ASUS P5P800-MX Motherboard
Windows 7 detects my video card which is xfx geforce 8400 se having a 512mb but only detects as 256mb video card?
When you turn on your pc press F10/F2 (depends upon the motherboard manufacaturer) to go to system setup, function will be according to the motherborad, check for an option named APG/APG Memory/Video Memory. and replace its value using up n down keys or page up/page down or +/- keys. and choose 512 value and maximum value is 256 or less than 256, your motherboard does not support the video memory more than it is selected.
Nov 28, 2009 | Pine Technology XFX GeForce 8400 GS /...
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP-95&fMTYPE=LGA775
Cheers!
Mike
Nov 12, 2009 | Abit IP-95 Motherboard
When I plug my monitor into my video card i get "no input signal" yet if i plug it into the onboard slot it works.could my PCI-E slot be bad?
Did you add a video card? If you have an AGP slot, it is best to put the video card in it. If so you need to go into the Device manager. Remove, disable or uninstall the onboard VGA driver. Go ahead and remove the PCI video card driver as well. Power down PC. Make sure monitor is hooked up to the Video Card, not onboard VGA. Power on PC. When Windows loads, it should detect the VGA card first, but if it detects the onboard first, ignore and don't setup onboard first. When Windows detects the card, load the necessary drivers when prompted. There is no need to reinstall the onboard driver for the video unless you wish to hook up two monitors.
Nov 08, 2009 | HP w1907 LCD Monitor
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
Disable onboard video of presario 5105rsh desktop pc
u can disable the the on bord vga in bios
enter in bios then u see in ide or advanced vga disable it then save settigns .
Jan 29, 2009 | Computers & Internet
No video from the board
Check the motherboard user guide for how to reset to default factory settings. If the BIOS is set to work with the on-board only and the on-board VGA is dead the motherboard is supose to detect that and switch to AGP. If is not doing that chances are not only the on-board VGA controller is gone ... the motherboard is gone too.
Try with a PCI video card.
1.Reboot with the AGP or PCI video card installed - assuming the on-board is gone but the motherborad still OK.
2. Press DELETE key
is supose to go in BIOS settings menu.
Browse and Look for on board VGA adapter ENABLE/DISABLE setting or something similar.
(My bet ? You need a new motherboard.)
Jan 12, 2009 | Intel Motherboard
Vedio controller
Your AGP (Advanced Graphics Port) slot is a Video Card Slot on *********** Board... It is usually a brown slot this is above the PCI (white slots). You have to have a Video Adapter ( video card ) for your PC to display ANYTHING, so you either have a card or you have onboard video which shared some of your system RAM for Video. This card is where you plug in your monitor, so if your monitor plugs into a seperate card then you probably have an AGP card, if it plugs in near the mouse/kb/sound then it is most likely an onboard video adapter.
Dec 18, 2008 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
