G15 key board
My g15 not woking properly the volume keys respond but do not alter the volume level also my G keys when set freeze gameplay for 4 to 5 secs then restores have i missed somthing when installing please let me know. ive just relized that the volume bar on lcd has changed from high to low between turning my machine on then off.
    Problem Solver:
  • 14 Answers
There is nothing wrong wuth the installation method only the key connection with the Printed circuit boards are not proper
Posted on Jan 23, 2008
How to turn ringer on
There are two possible reasons for the handsets not to ring when they are functioning properly. 1) You have the ring volume set to off. This would be done on each handset. With the phone in standby, press the volume up button until you reach the desired ring volume.
(There are 4 volume levels.)
2) You have toggled on the Do Not Disturb feature; this will apply to all of the handsets when started on one handset. Press and hold the # key (below 9) on a handset that is in standby. You should release the key when the phone stops showing the DND symbol. You can actually set the length of time in hours for the DND feature by pressing a number key (1-9) when the screen shows a prompt. If you don't press a number key within 5 seconds, the DND remains on until you press and hold the # key again.
If neither of the above solutions work, you need to check that the base is receiving calls properly. Check if a different phone (preferably a basic wired phone) rings properly when you get an incoming call. If another phone doesn't work, you'll need to check your wiring. If another phone works, contact Uniden if the XDECT8015 is under warranty.
Uniden has the manual for the XDECT8015 on the product page: http://www.uniden.com.au/australia/p_xdect8015_1_index.asp . The direct link is http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_8015_1_OM.pdf .
I hope this helps.
Oct 03, 2014 | Lands Phones
How to reset a windows phone
Try these fixes if, for example, your phone randomly reboots, freezes or does not switch on, if an app crashes, if you have sound problems, or if the screen is blank:
1. Restart your phone.
Press and hold the Power and Volume Down keys simultaneously for 10-15 seconds. Release and the phone will restart. After this operation, you may need to set the date and time on the phone.
If the problem persists, reset and restore your phone as instructed below.
2. Reset and restore your phone.
Important:
  • This erases all personal content on your phone and restores the factory settings.
  • Before continue with the reset, make sure your phone's battery level is above 50%. To check the remaining battery life, go to Settings > battery saver. If you are not able to check it, or the level is too low, charge your phone for at least 20 minutes.
Reset your phone by using the built-in option in the phone settings. Select Settings > About > Reset your phone.
However, if you cannot access the phone settings, follow the steps below:
a. Disconnect the charger. Press and hold the Power and Volume Down keys simultaneously. Release the pressed keys when phone vibrates and then immediately press and hold the volume down button until the phone displays an exclamation mark (!) on the screen. Release the volume down key.
b. Then press the volume and power keys in the following order: volume up, volume down, power, and volume down.
c. Wait for your phone to reset, during the reset you will see gears rotating on the screen for up to 5 minutes, after which the screen goes blank for ~30 seconds and then your phone will restart.
d. Go through the initial phone setup. Make sure that you have the date and time set correctly on your phone (Settings > date+time).
Sep 02, 2014 | Nokia Cell Phones
My avail doesnt respond to touch
Try to perform hard reset by Pressing and holding the combination of the Power key+ volum up key+ Menu key when the phone is off. When it enters the boot loader mode use the volume key to scroll --> select wipe data and factory reset --> select yes and wait till the phone reboots.This would solve your issue... :)
Mar 17, 2013 | ZTE Avail Z990 - Black at&t Smartphone
Keyboard won't type
go to keyboard setting in device manager. check all keys if work properly. u might have your keyboard set to a different format
Oct 22, 2017 | Logitech G15 Gaming Keyboard
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
Have bought a second hand philips 28pw6506, it has no remote control. Do you know how to change the aspect ratio or size of picture on screen? Have looked through the menus with the button on top of the...
Hello
To change its picture aspect ratio, you have to go to its menu. As you haven't its remote control there is an option for that, mentioned in its user manual. I hereby send it to you. Do the same and access the aspect ratio.
The television set has 4 keys which are located
on the front or the top of the set depending
on the model.
The VOLUME - + (- Vol +) keys are used to
adjust sound levels.The PROGRAM - + (- P +)
keys are used to select the required programmes.
To access the menus, simultaneously hold down
the VOL- and VOL+ keys.The PROGRAM - +
keys may then be used to select an adjustment
and the - VOL+ keys to make that adjustment.
To exit from the menus, hold down the 2 VOL-
and VOL+ keys.
Note: when the Child Lock function is activated,
these keys are unavailable
OK.
Dec 21, 2010 | Philips 28PW6506 28" TV
Creative Zen doesn't respond to the buttons or music selector
Most Creative zen mp3 players have a slide power on/off button, when slided completely back it sets the mp3 player on key block, maybe it's on key block.
Nov 12, 2009 | Audio Players & Recorders
Volume level display
it sounds like your laptop drivers aren't working properly.. possibly the program dealing with your sound volume is corrupted or missing.
I'd try reinstalling your keyboard/touchpad drivers. what is the make and model # of your laptop?
Dec 28, 2007 | Lenovo ThinkPad R60 with Wireless Wide...
I BOUGHT A FRENCH G15 AND NEED ENGLISH KEYS FOR THE BOARD
Normally the keys on a keypad are standardised in designe. Please go through the cataloge you may find the english version of the keys equivalent if you dont find the details then consult the shop from where you picked up the equipment for obtaining details through the customer support.
Sep 06, 2007 | IBM PS/2 Enhanced Keyboard/Mouse 71G5791
My phones speaker volume won't go up. It just stays on the lowest setting/
open the set and clean the volume buttons.Any leakage or shoting in keys especilly volume keys creative this types of problems
Mar 07, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
David Payne
David Payne
