Question about Cooktops
Need help fixing Jennair JEC0530 Cooktop problem
The burner in customer control element is no longer working. I tried to touch the control to turn it on, but nothing happened. By reseting main power, I was able to make the control work - meaning it seems starting when I touch the control to turn it on. But there is no heat from the burner, and the fan stops after while, and then the control of the customer control element got disabled - until next main power resetting.
my question is how to check what's wrong? Is it the burner is broken? If so, is it easy to replace it? And where to get the parts?
Thanks!
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 619 Answers
SOURCE: JennAir Elec Cooktop Problem
The selector knob having lose contact the elements are for full adjument , the wire connection are rust and corroded need to clean terminal of elements.
Posted on Jan 05, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Posted on Mar 11, 2008
Anonymous
  • 161 Answers
SOURCE: GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Posted on Jul 15, 2008
Anonymous
SOURCE: Need part# 786106 (coil element module) for Whirlpool cook top RC8920XRC
I have the part. New in box.
Posted on Apr 17, 2009
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Mar 09, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Jan 04, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
Dec 07, 2007 | Maytag MEC5430BDS Electric Cooktop
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktops Logo
174 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
