Question about Yamaha HTR-6030 Receiver
My yamaha htr 6050
Hi everyone, got my htr 6050 yamaha receiver two months ago and it worked great until two days ago. My direct tvdvr hd is hooked upthru it as well as my ps3 which I also use to watch blue rays and dvds. The sound from my receiver no longer works from my ps3. The cable sound is great. The speakers in my tv work fine from the ps3, just not the receiver. Since it all goes thru the receiver, it seems strange sound works from the plasma tv, not the receiver. any help would be greatly appreiciated,
thanks jeremy crikket44@hotmail.com connections look good
    New Friend:
  • 120 Answers
Make sure you speakers are turned on on the receiver,
Posted on Jan 24, 2008
Make sure your audio output on your PS3 is configured properly. You have the ability to chose which port the audio is coming out of.
The 6050 does NOT process audio signals coming in on the HDMI port. The amp is weak, I had one. With the 6050 you will have to use the AV multi coming out of the PS3 and use the special cable that came with the PS3 to convert that signal to the RCA and connect that to the 6050.
Posted on Jul 27, 2008
Have you checked the video cables from the ps3 try a differant pair to see if that resolves the issue..gl
A HTR-6050 Troubleshooting - Receiver Turns Itself Off
Hi Elvis,
Does it turn off at the same time everytime? Is there a timer function that still might be on?
Is it overheating?
May 18, 2011 | Yamaha HTR-6090 Receiver
While I'm watching TV through my Yamaha HTR 3063, the video cuts out for about 2 sec but audio works fine. This happens about 10 times a day. My set up is as following, a outdoor coax cable to a HD dual...
Well, it can be one of two things:
a One of the HDMI cables or
b The receiver HDMI interface.
I have heard is said from more than one source that Poor HDMI cables are a headache, even if
new.
Here is a procedure you can try out.
1 Connect up the Plasma to the DVR directly with each cable alternately until
you find a defective one that demonstrates the same problem you are showing
with the receiver connected. If it doesn't manifest the problem go to step 2
2 Get a can of compressed air, such as the small cans sold for dusting out computers.
(about 5 dollars at Walmart). Visually inspect each of the HDMI connectors on the back of your receiver. You may find a pet hair that is the culpret. BLOW all the connectors clean with the can of air.
3 Reassemble you system and see if it still manifests the same problem. If it does, go to
step 4.
4 Time to find out if your warranty is still in effect with Yamaha. If it is, great, if not, Oh well.
Contact them anyway. They may still help you if it is very recently out of warranty.
I hope this helps,
Best Regards,
Mark
Jan 28, 2011 | Yamaha HTR-6030 Receiver
new.
(about 5 dollars at Walmart). Visually inspect each of the HDMI connectors on the back of your receiver. You may find a pet hair that is the culprit. BLOW all the connectors clean with the can of air.
step 4.
I hope this helps,
Best Regards,
Mark
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
What is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
Jul 25, 2009 | Yamaha RX-V563 Receiver
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Apr 23, 2009 | Yamaha RX-V757 Receiver
How to hook up everything!
I have similar equipment.
You should use an audio digital cable to connect the bluray to the Yamaha receiver and another digital audio cable to connect the HD box to the Yamaha receiver.
Hope this helps.
Dec 23, 2008 | Yamaha HTR-5650 Receiver
Yamaha HTR-6030, Sound only from Front Speakers
u could have it cross wired some systems wire in sequence not always pos and neg
Aug 23, 2008 | Yamaha HTR-6030 Receiver
6050 yamaha receiver issues
the problem is how you wired it, guess you plugged the ps3 directly to the tv. to hear the ps3 through surround sound, you would have to wire it through the reciever like everything else...
Jan 28, 2008 | Yamaha HTR-6030 Receiver
Yamaha HTR-6030 Receiver Logo
701 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
