Kenwood ka 405 integrated amp
When i turn it on the meters light up --there is no click in the amp as there was before.There doesnt seem to be a burnt odor in it.have checked both fuses and test ok. i really cood use all the help i can get. have had this guy for over 20 yrs and want it back working again, If i cant repair it i can find another,but wood like to give it a try
  • wjmullin Jan 23, 2008
    oh yes ,im getting no sound anywhere
  • wjmullin Jan 24, 2008
    there is no burnt smell in the is not a tube type.
  • 70 Answers
First off, SAFETY FIRST!!!!!!
Never, never, never open a unit unitl it has been unplugged from the wall for a couple of hours. Especially if it is a tube unit. The filter cap (capacitors) maintain a charge if the unit is plugged in, and they do not discharge when unplugged for a long time. Literally, if you were to accidentally touch one while still charged it would throw you accross the room.
Tubes can eaily be removed, but finding a place to check them is another story altogether. If you look through your Yellow Pages (Redd, Green, Blue, whatever) look for an older repair place. Newer shops don't what analog is so they definatley won't have a tube checker. One quick, inprecise way is to turn the unit back on with the cover off-mind you don't touch anything-and the tubes will lite up with a dark amber glow. Any that does not will be bad.
Since your not smelling anything burnt (older units will normally burn a component), if I was checking things out I would look at components in the amplifier circuits. You said the unit turns on a the meters are lit so the pre-amp section seems OK. This could tested if you have another amplifier. Take the pre-amp outputs from the KA-405 into another unit to verify signal does in fact exist.
Either way, it will not be something serviceable by you (unless a tube, but at 20 years old, I don't think it has tubes, besides the unit looks too small). I know some people here that work on older units if you do want it repaired. But check locally first.
Hope this helps a little
Posted on Jan 24, 2008
  • Jeff Sapper
    Jeff Sapper Jan 24, 2008
    Just caught where it is not a tube amp...
    definately needs to be "taken in".....
    Hope it can be fixed.... and thanks for the rating.
  • 107 Answers
You said that there is and odor in it? check for a burnt resistor and your output transistor (if its a transistor type) or tubes. ( but I dont know how to check tubes, hope you know how)
open your unit and turn it on, you have to identify what is causing the smell. and check around that part for some other malfunctioning part. like resistor, capasitor, diode, anything else.
and if you know the voltage of that part, you should check the voltage, wether it needs more or to much.
  • Mark Payas
    Mark Payas Jan 25, 2008
    all I am saying is to observe it in on, not to touch any capacitors ( capacitors had been printed with there capacity and the farad in it) or parts. then after, its ok to check. well, we know what are the parts of the unit has a high voltage and low. ofcourse if you want to repair it, take the risk but with precautions. know what you are doing and what is the step by step procedure.
    sorry for any misunderstandings about the units failure..
    peace!! ^.^
    check the main parts like the transistor, or mosfet, but before put a signal input to the amplifier then hear it to the speakers, if there is no output sound from the speakers try to check any crystal diode, if the crystals are in good conditions, check your relays switch to the speaker.. after all the good work, and still there is no progress, check all the components one-by-one (unpluged the unit, discharge any high voltage capacitor).
    if it is an IC type amplifier, and you know that the IC is causing it then just take it to any repairshop.
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Kenwood integrated amplifier ka 895. Why no sound output?
How do you get to know that the unit turns on .After power up what are sequences happening i can help you
May 26, 2015 | Kenwood Audio Players & Recorders
Integrated Amp to Power Amp
Unfortunately, there is not. You risk over driving the amp if you do that
Jan 27, 2014 | Audio Players & Recorders
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
Dead Kenwood Home stereo Amp. KA-2002
Some says it is only dead when it is buried.
Open it up and check, ( Be sure it is unplugged)
Only if you feel you can DIY or have a tech do it for you.
Oct 06, 2012 | Kenwood Vintage Model Ka-6006 Stereo...
The model number is Kenwood KA-894 integrated Amplifier I'm trying to find out how many watts. Thanks
The manual with 'specs' is here. Take them with a grain of salt because it's impossible to produce more audio watts than are consumed electrically (250 total).
Dec 25, 2010 | Audio Players & Recorders
Does it look like this?
Mar 27, 2010 | Kenwood Audio Players & Recorders
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dec 27, 2009 | Kenwood VR-405 Receiver
I have a kenwood stereo integrated amplifier KA 791 and the dual cassete KXw892, niether will come on. when plugged in the standby light only comes on. the reciever and cd player components come on fine?...
That system came with the kt591 tunner in a bundle which consisted of what you call the Kenwood Spectrum 700 rack system, you had to plug the tuner into the wall and then plug the amp into the tunner if you didnt , when you turn the amp on you just get a relay clicking noise and nothing turned on.
Sep 14, 2008 | Audio Players & Recorders
1,158 people viewed this question
