Question about Canon PowerShot A75 Digital Camera
Camera closes after power on
My Canon powershot A75 got a bump recently. It opens and makes three beeps, posts a message "E18" and closes immediately after. Any solutions?
  • mugugumbo Jan 25, 2008
    As I cannot open the camera myself I will get a technician to have a look, using the advice you gave me.
    I thank you very much and will ge back to you after the tech. has looked at it
    Mugugumbo
    Problem Solver:
  • 18 Answers
Since camera was bumped, the proiblem is in the lens assy and it's inability to extend out! Send it to us for a N/C estimate via e-mail. About 1/3 of the digital cameras I receive for repair have an extention of lens problem. www.flcamerarepair.com
Posted on May 20, 2008
    Problem Solver:
  • 6 Answers
"E18" Error seems to be a code related to and barrel extension problems. I have broken down these problems into three categories which explain the variety of causes (or lack thereof) and solutions that people have reported. The solutions are referred to in the numbered paragraphs below, and then described in detail afterward. The three categories are:
  1. Batteries that run out of juice mid-extension. Problems such as these appear to be reset-able through either powering off and on or the A/V cable connection method.
  2. Physical obstructions preventing the full extension/retraction of the lens. These can include things like dust or sand in the mechanism. As the case (and lens barrel) are by no means impervious to the introduction of foreign matter, even if you are very careful with your camera, contamination is possible. Depending on the size of the obstruction, and how sticky it is, it may be dislodged by blowing air on it or tapping on the camera.
  3. Mis-alignment of the lens can also cause the E18. The cause of the alignment problem can be either blunt force (dropping) or substantial grime in the mechanism. These types of problems can sometimes be fixed by pushing the mechanism back into alignment, sometimes in combination with a cleaning method.
NOTE: Items 2-3 above may involve large and/or sticky grime that is difficult to impossible to remove from the outside of the camera (by blowing or tapping), and may require that the camera be opened.
Posted on Jan 23, 2008
E18
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
The problem usually happens because dirt or sand get into the lens mechanism. To repair it, visit this link and follow all the steps.Rating the solution is highly appreciated..
May 25, 2010 | Canon PowerShot A75 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera got wet and is now showing a e-18 message
e18 is a general error code for canon. if you got from best buy repost if you got the accidental plan from them
Apr 29, 2008 | Canon PowerShot A75 Digital Camera
There is warning (E18)on screen of my dijital camera canon powershot A75
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 01, 2008 | Canon PowerShot A75 Digital Camera
E18
The E18 error is fairly common. Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 04, 2007 | Canon PowerShot A75 Digital Camera
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
CANNON A520 POWER SHOT DIGITAL CAMERA
Tab on the camera. E18 is a stuck lens. This is common on this camera. I'm not saying this will fix it, but don't break it.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A75 Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
