I have a Soyo Monitor, Model MT-NI-DYLM1998.
It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect.
The Soyo monitor stays blank (black) except when it is turned on, the monitor shows a picture for 2 seconds and then goes blank again.
I run windows XP with the latest update. It appears to be hooked up correctly. It does not come on when I move the wire in, only when the monitor is turned on, and then only for a few seconds.
Any ideas?
Robert Burlingame
425 people viewed this problem
This solution has been voted best by the Fixya Commnunity
I have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Testimonial: "Thanks. I suspected it was broke."
I have purchased a Soyo 17-inch MT-NI-DYLM17 monitor. It didn't come with a setup cd. I have a PNY GeForce 6200 video...
Have a 22'' Soyo LCD MT-NI-DYLM2286 and without any warning the the disply is blank ... power light comes on solid ......
SOYO 19 TFT LCD Will not come on. Says "no input signal" Re-bot does not work. Everything is plugged in.
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating...
the screen keeps going to black. Sometimes for a sec or minutes and then comes back up unexpectadly. Is the monitor...
Monitor shows an image only for one second upon turning on. Says RGB in upper left corner, then goes to black.
monitor turns on then goes black turn it off then on comes on for three seconds or so then goes black
