Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery Front Loader doesn't spin
My 7-year-old machine "finished" a cycle - dial was at end, lights out and latch released, but clothes were wet and soapy. The timer had apperently kept running during the rinse stage, but the drum did not spin and the water did not drain.
Emptied the tank, siphoned off the water. Fill works ok, but machine does not spin or drain.
I called the support number attached to the machine (866 203 1839) and got a redirect to an Electrolux service maze.
Located a local service provider on the Electrolux support tree and he diagnoses bad water pump. He replaces pump, fills the tank, runs it through a spin cycle and pronounces it fixed.
I was one load successfully. Second load "finishes" with dial at end of cycle, tank full of soapy water. Machine does not spin.
    Problem Solver:
The washer bears a plate with a toll-free number leading to a phone maze for support. I ultimately reached a list of local (within my state and metropolitan area) service providers. I called the nearest one and a serviceman came to my home within a few days.
I asked what could cause the failure and the repairman told me that a coin could enter the waste stream and block the pump, causing it to overheat. The failed pump turned out to have a nickel inside.
The repairman quoted me prices for brand new and slightly used water pumps. I elected to go with a used pump, but was a bit disappointed that the repairman did not have a replacement pump with him. After a few more days waiting, my washer was back on-line. Unfortunately, the replacement pump failed two cycles after installation. By then I had read about the involvement of the controller board in some cases of water pump failure.
I spent a few anxious days of phone tag and missed appointments (indicative of a low- to moderately-skilled operator) before having to threaten the operator with reversal of the credit card charges. The repairman returned promptly with a new pump and installed it with no additional charges.
My washer has been satisfactorily functioning since (about a month). I would rate this operator (Check Appliances of Los Angeles) as satisfactory regarding demonstrated technical skill and knowledge, but needing to improve in customer service.
Posted on Feb 24, 2008
    Genius:
  • 1,554 Answers
The CCU board is likely at fault see one of my discussions on this here
these boards have intermittent failures that will drive you wacky.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Feb 14, 2008
6ya staff
SOURCE:
Clothes come out musty
I would put in some bleach and clothes that can handle it without damage and run a wash cycle. Leave the door open when you are done using the machine, or at least un-latched. There are commercial products, but bleach will do the same thing. You have stuff growing on the gizzards inside the drum, and bleach will likely kill them. They like dark & humid places.. guess what... that's your washer with the door kept latched.
Aug 15, 2014 | Kenmore Elite HE5t Washer
How do you fix Frigidaire GLTF2940FS slow final spin cycle?
if this is a front loader modelthen most likley cause is worn out motor brushes
Sep 17, 2017 | Washing Machines
I have a Frgidaire Gallery series front loader washing machine. It just started pausing itself mid cycle. I have to keep checking on it and repress the start button. It doesn't seem to be spinning...
I have the same problem ,, and i called frigidair and they didnt seem to care my unit is only a year old ,, im so furious right now ,, now i was looking on the recall list and the water pumps are on the recall list on selected models i know with mine it will stop then pause and not drain the water out ,, maybe some can help us out :)
Sep 06, 2011 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE washer -clothes still wet sometimes
checked the drain? didi you physically open the drain pump asssy, and clean the filtero out???
Feb 09, 2010 | Washing Machines
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
The washing machine wont rinse - Kenmore echo care system
without more info its hard to tell but it sounds like a bad timer. can you advance it manually a few notches or run it in another rinse cycle.
Sep 04, 2009 | Washing Machines
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
317 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
