Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
User manual i dont know how to print the bothside pages and books and also how to adjust the paper
Change ip address
Posted on Mar 07, 2008
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
How to adjust paper size in Cosmi perfect PDF creator essentials?
With most PDF creators a virtual printer is created when you install the software. That is where you would adjust the paper size. When you print to your PDF printer, before you click print, click on the PDF print options, Page Setup, and the select the Paper tab. Choose the paper size that you would like the PDF to be formatted to. Click OK and the print to the PDF writer printer.
Additionally, Cosmi includes user manuals when you install their software. It can be found here:
1. Click Start
2. Select Programs (or All Programs)
3. Select the name of the program you just installed (you may have to Select Cosmi, then Select the program name)
4. From your program's sub-menu, you should see Manual or PDF Manual.
Mar 20, 2011 | Cosmi Perfect PDF Creator Full Version for...
How to print on both sides of the paper in canon lbp2900?
what is the option to print bothsides in cannon lbp2900
Oct 19, 2010 | Canon Office Equipment & Supplies
Printing on a customise continuose paper
Check the printer settings about page length by the procedure given in the user manual.
If OK check your software if it is giving soft commands to adjust paper lengths.
Sep 28, 2009 | Epson LX-300 Matrix Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Printing
    Dear jamin4volks;
    As per this excerpt from the Oki B4350 User manual:
    "FACE UP AND FACE DOWN PRINTING
    For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
    For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
    Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
    This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
    Hope this helps;
    Frank
    Apr 18, 2008 | OKI B4350 Laser Printer
    Lost manual
    Here is a link to the user manual that you can print: http://www.generalmanual.com/Facsimile/Panasonic-KX-FG2451-Plain-Paper-Fax-Copier.htm Hope this helps:)
    Sep 04, 2007 | Panasonic KX-FG2451 Fax
    Computers & Internet Logo
    248 people viewed this question
    Top Canon Computers & Internet Experts
    Computer Links
    Tony
    old marine
    old marine
    Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
