Question about Avocent AMX 5010 (AMX5010-AM) 64-port KVM Switch
Apex outlook kvm switch
I have 10-15 serevr's hooked up to a Apex kvm switch was working fine but now few servers not shown in the screen..i put off teh kvm and on it agin but stil teh problem persists
  • 64 Answers
Ok so this is not a hub, but in my experience with similar setups, it comes down to a handful of possibilities.
  1. As with djnick's suggestion, older cables can give problems and if the ports are in an area where they may attract dust, or be poorly groomed ( meaning cables are dangled or twisted and crossed, may also be under excess strain )
  2. Excess heat or moisture - check around the area, place a thermometer near the unit and check this against safe operating temps and humidity ratings ( should be on the unit or at least in the handbook)
  3. Get some pen and paper and make a note of how the setup is currently setup so as to avoid confusion when re-connecting the cables.
  4. Take particular note of the ports not shown or responding, and test each one in turn with a lead that is known to work, this will only eliminate bad leads, not bad ports.
  5. Try using the leads from bad ports in good ports, this can also help eliminate the good eggs from the bad ones.
  6. The only other way is with to blast the ports with a can of compressed air ( not available in all countries due to safety concerns with the product ) - may have to resort to another method, but do take care and as with most units of this nature try to avoid using suction on the ports or internal components.
  • Worst case scenario you end up back at square one and the problem remains. This could also mean the problem lies with the software that is running, or any firewalls in the network may also be blocking the ports & may need a rule created to allow these ports to work.
  • Consider every option carefully as sometimes the solution may be closer then you think.
Posted on Jan 23, 2008
  • 1,067 Answers
Bad ports then cables ?
Lcd tv goes blue screen
Blue Screen usually means you have no video source, but also it can be a bad cable, bad signal, or week signal. I will try to hook it up to a dvd and test it on another source. However the screen should be all blue aand not blue lines, if you can email me a photo of the screen I will be able to properly address it.
Tony Mitri
Feb 15, 2014 | APEX Digital Inc. Apex Digital 32" 720p...
Unlocked my apex tv but now it only shows blue/static screen. Help!
The chroma processor section should be troubleshooted. It is a skilled work.
May 17, 2012 | Apex Digital PF3225 32" TV
Apex LD3249 LCD tv.picture jumps
The tv Tuner board,that where the coalax broscast signal come in is dead.Tries websites like, to buy a refurbish Tuner signal board for the replacement.
Jul 06, 2010 | Apex Digital LD3249 LCD TV
Apex Digital TV Model: 1919. Worked fine for a
Power supply issues or shorted horizontal output transistor. Probably not worth having repaired unless you DIY....
May 17, 2009 | Apex Digital LD1919 19 in. LCD TV
How to unlock my Apex TV #at2002 with only KEY shown in the corne
Press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels..
Please rate this Fixya solution
Jan 20, 2009 | Apex Digital PF2020 20" TV
No sound and picture does not fit tv screen
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ...
Jul 25, 2017 | Apex Digital AT2708S 27" TV
How to set up Compaq Series 4110 8-port KVM Switch & select computer
The Compaq 4110 KVM switch was actually manufactured by Apex which is now part of Avocent. Your switch is Compaq's rebranding of the Apex/Outlook EL-80DT from Avocent.
The key to display the KVM switch menu should be PrintScreen. Here is a link to the user manual:
Your answer seems to be on page 34.
May 30, 2008 | Compaq 242695-001 8-port KVM Switch
Compaq 8-port kvm switch firmware
HP Parts supposedly still stocks the EPROM for this model, so you can try to order it from the HP Parts Store. Check for part 340579-001.
Mar 13, 2008 | Compaq 242695-001 8-port KVM Switch
KVM switch control
APEX switches are manufacturer by Avocent and rebranded by Dell, HP/Compaq, IBM, etc.
The keystrokes should be CTRL-CTRL (Hit control 2 times). Some Avocent switches also use ALT-ALT or SCROLL-SCROLL.
Jan 12, 2008 | IBM NetBAY 09N4290 4-port KVM Switch
No sound
How do you have it hooked to the dish? If you are running it in RF switch to audio video.
Nov 29, 2007 | Apex Digital GB5108 51" Rear Projection...
Avocent AMX 5010 (AMX5010-AM) 64-port KVM Switch Logo
910 people viewed this question
Top Avocent Computers & Internet Experts
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
