Question about HP DeskJet F380 All-In-One Printer
SCANNER DOESN'T WORK
I can;'t get the scanner to work scanner wont start
  • 24 more comments
  • Anonymous Jan 27, 2008
    f380 worked on old imac. Got the new imac 10.5 ox. Downloaded/uninstalled many times. Never get the setup assistant, and scanner is not recognized.
  • Dyami Jan 30, 2008
    My scanner doesn't work either, when I use the scanner program it says there are no scanners pluged in the computer, any solution?
  • grundge Feb 07, 2008
    printer works ok but no luck geting scanner to respond any ideas
  • Anonymous Feb 21, 2008
    New HP Pavilion notebook computer with VISTA + new HP F380 printer; works fine when copying or printing from the Internet or from Word or from emails but won't print Excel documents & won't scan (gives a little hiccup then does nothing) -- no error message, just nothing. No effect from rebooting, disconnecting & reconnecting all plugs, new ink cartridges, different documents nor changing Excel documents from Office 2007 format to old 2003-2006 format.
  • Helioman Feb 22, 2008
    F380 HP deskjet doesn't scan when I hit the scan button.
  • LATHESON Apr 29, 2008
    i have the exact same problem. When i press the scanning button nothing happens and only the power button icon startes to blink for about a minute and then stops.
    I think its because i have Microsoft Vista Home Edition.
  • Othomas Apr 30, 2008
    Can't get the scanner to work. What do I do? The power light just blinks.
  • Anonymous May 07, 2008
    i have the exact same problem. the light jus blinks
  • Anonymous May 10, 2008
    Scanner not work
  • thepitt May 12, 2008
    it only blinks when I try to scan.
    i'm using windows XP
    when I try to scan, it only blinks. ALready went to HP web site and it doownloaded correct driver. How do I scan?
  • Anonymous Jun 09, 2008
    mie scanner doesnt work
  • Anonymous Jun 11, 2008
    I have windows vista, all the features work except scanning. I am USB installed and the "on" light blinks when I try to scan it stops in about 30 seconds and nothing else happens.
  • Anonymous Jun 13, 2008
    Won't scan
  • kristyjane Jul 02, 2008
    the printer works, but the scanner will not. when i press scan, the power light flashes, and nothing happens
  • zenon1994 Sep 21, 2008
    have windows vista home premium. HP deskjet all in one F2120. Wacom Intuos 2 Graphics tablet. Scanner worked fine until I installed the driver for the tablet. Now the scanner won't work unless I uninstall the tablet driver.
  • Anonymous Oct 07, 2008
    scanner won't work, when I press the scan button the power light flashes but nothing happens. I am using Vista
  • Anonymous Oct 10, 2008
    I had the F380 working fine on my old laptop (Dell) but when I bought
    anew laptop (HP Pavilion tx2117cl) it doesn't scan. I want to scan a
    document and send it by email to someone.
    This was easily done on the
    Dell - the nice HP window would pop up and I was sailing. Now, nothing
    happens.
    When I tried loading the drive (by cd) onto my new laptop's
    hard drive it wouldn't receive it. (My new laptop is running Vista -
    might be the problem) I had to first get an update from Microsoft and
    then download the driver through the internet.
    I really need to have
    this scanner working so I can scan and send documents daily. Thanks.
  • Anonymous Nov 08, 2008
    I put a picture in the scanner to put it onto the net so i pushed the scanner button and the power light flashed, and then nothing happened.
    how do i get the scanner to work?!?!
    when i push the scan button the power light flashes but then nothing happens\
    how do i get it to work
    im using windows vista
  • Anonymous Dec 19, 2008
    i think its vista that doesnt work with the scanner because it wont install the disc
    on my old computer it worked fine
    now it will print and thats all
  • Anonymous Feb 05, 2009
    I have the same problem.. windows vista and the scanning doesnt work...
  • peprichard11 Feb 16, 2009
    I can't get my HP F2120 DESKJET ALL-IN-ONE TO SCAN PICS AND DOCUMENTS, iT WILL ONLY PRINT AND COPY.
  • Anonymous May 12, 2009
    its a vitcg
  • Anonymous May 11, 2010
    Hi
    I need to know your operating systems to fix the problem and find the solution. I think you have Widows XP Home edition/Service pack1/?Lower than this editions. If you upgrade your OS or update your OS by connecting to the internet if you have licensed OS. This will resolve your problem I think.
    Regards
    Arun
  • NITIN  BABBAR
    NITIN BABBAR May 11, 2010
    are u able to do copy or not?
    Problem Solver:
  • 14 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00803473&lc=en&cc=ca&dlc=en&product=1128296&rule=20851&lang=en
You can also attempt to reset the AIO:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00637484&lc=en&cc=ca&dlc=en&product=1128296&rule=20851&lang=en
For the Mac (possibly):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&cc=ca&dlc=en&product=1128296&rule=20851&lang=en
Posted on Jun 12, 2008
    New Friend:
I have a deskjet f4580 the printer and the copier works but the scanner doesnt...i have a acer laptop with windows 7. i installed it once before and everything worked just fine. i reinstalled it and the scanner will not work. when i push the scanner button the power light flashes also the light next to the wireless button flashes orange how can i solve my problem
Posted on Aug 07, 2011
What is a scanner strip
Posted on May 06, 2008
    Problem Solver:
  • 18 Answers
All scanner problem basically come from scanner strip.so just replace the scanner strip.
Posted on Feb 20, 2008
6ya staff
SOURCE:
Plustek Optipro 9636T - working under Windows 7.
If you scanner only has Win XP drivers, then you have only two choices as those drivers wont work on WIN 7. One is to buy a new scanner, as you have already suggested. The other is to create a virtual machine, load WIN XP onto it, and then install the scanner drivers on the virtual machine. This should work fine as I do it for a piece of software that only works on WIN XP, however it is a bit of a inconvenience to use.
Aug 20, 2017 | Plustek OpticPro 9636T Flatbed Scanner
Scanner wont scan
Try using the Lexmark Productivity Studio. To access that, on your computer, click on Start > All Programs > Lexmark 2600 Series > Lexmark Productivity Studio.
If that doesn't show up as an option, install the Lexmark Productivity Studio using the installation CD of your printer.
Oct 23, 2012 | Lexmark X2670 All-In-One Printer
1992 pontiac bonniville dies & wont start , sets a while then starts like normal. doesnt matter cold or hot
When it doesn't start check for fuel pressure, spark and injector pulse. If you got access to a scanner that could read live data check if you get an RPM reference. Check and report your findings.
Jul 07, 2012 | 1992 Pontiac Bonneville
Car wont start
your missing a fuse or the ignition switch is not turning it on
Mar 31, 2012 | 2000 Mercury Grand Marquis
My usb port wont reginize my usb stick
try putting your USB stick in the port provided at the back side your PC !!! if it doesn't work try in your friends PC if it doesn't work there then your USB stick must have failed!!
Jun 15, 2011 | Computers & Internet
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My car wont start the battery is fine dont know what the problem is please help
IF the car cranks over but doesn't start you need to see if you have Spark and Fuel. IF it doesn't crank, check starter and related circuit, tapping on starter will sometimes help to get it rotating. Check all fuses, and make sure battery terminals are clean and tight. Have someone or yourself connect a scanner DTC reader and see if you have any engine computer faults. If manual transmission make sure your clutch pedal switch is not missing the bushing. Aftermarket alarms can cause no starts also, but usually a "no-crank" situation.
May 17, 2011 | 1997 Acura SLX
Computer doesn't recognize scanner
maybe the cabel is broken, what type of cabel do you use for connecting to pc? if usb try to change the usb port, if this doesn"t work change the cabel. btw the scanner has to be started.
Dec 15, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
4,513 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
