Question about Maxtor Hard Drive
Ntldr is missing in my operating system? how can
  • chopperone Feb 09, 2008
    missing ntldr how do i get it back
This problem occur due to operating system,for example if two hard disks are atteched to computer without master and slave, the files from hard disk cannot be loaded in to Ram.So we have to care full......
the other reason may the h.d.dbe it have other operating system.
Posted on Jan 30, 2008
    Genius:
  • 1,226 Answers
Try to see if you have inserted a non bootable floppy diskettes, if there is no diskette then maybe you'll be guided here:
http://www.computerhope.com/issues/ch000465.htm
may this will help you.
melnavz
Posted on Jan 23, 2008
6ya staff
SOURCE:
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Tip
NTLDR Missing in your Desktop or Laptops PC's
Better if you have a bootable disk to perform this action.(NOTE!)
This tips applicable for all Microsoft Windows Operating System such as XP2,XP3 or Windows 7;, Ultimate,Home and Professional use:
A). Scanning virus on your pc and accidentally or automatically delete your NTLDR system file in your system.B). It will occur when your system unit restarted, and when the system try to boot the specified hardware ex. hard disk where the operating system where stored. this text will appear in your screen("missing NTLDR"). then you cannot proceed to windows. cause the system files cannot boot to it's main purpose.C). NTLDR is main system file for booting up the configuration that's being set in your BIOS system.
on Apr 08, 2010 | Computers & Internet
17HEWLET-PACKARD NTLDR IS MISSING
See the following web site for help on fixing this problem or alternatively, download a copy of Hiren's Boot CD and burn this CD image file (ISO) to a blank CD, then boot your computer from the CD and take the option on the boot menu to Fix NTLDR is Missing.
Jan 12, 2012 | Compaq Computers & Internet
Ntldr is missing in intel pentium3
Dear samethlida03 NTLDR is  a key boot file in your operating system.without ntldr the system will not boot fore more information how to fix this issue please visit  http://www.quickonlinetips.com/archives/2005/12/ntldr-is-missing-press-any-key-to-restart/ this link.
Thanks
Jun 19, 2011 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
What is NTLDR error sir?
NTLDR (abbreviation of NT Loader) is the boot loader for all releases of Microsoft's Windows NT operating system up to and including Windows XP and Windows Server 2003. NTLDR is typically run from the primary hard disk drive, but it can also run from portable storage devices such as a CD-ROM, USB flash drive, or floppy disk. NTLDR can also load a non NT-based operating system given the appropriate boot sector in a file.
NTLDR requires, at the minimum, the following two files to be on the system volume:
  • NTLDR, which contains the main Boot loader itself
  • boot.ini, which contains configuration options for a boot menu.
This error means that NTLDR is missing somehow from your computer,hard disk problem,virus.etc
You can go to that page and follow the instructions exacty as he says and your problem will gone:)
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 12, 2010 | Abit KW7 Motherboard
NTLDR is Missing Press Ctrl+Alt+Del to Restart Problem! No CD No Floppy to reboot! How to fix it?
its necessary to you a bootable cd or floppy system disk. ntldr is part of the hard disk partition data, it this partition if missing then you cannot open your system until you use bootable operating system.
Jul 15, 2009 | Compaq Evo D500 PC Desktop
Ntldr missing
boot the computer with windows cd and press R for recovery console then type
Copy [drive]\i386\ntldr c:\
Feb 23, 2009 | Microsoft Windows XP Professional for PC
Ntldr missing error
There are two options are available
1> Reinstall Operating System but data would be loss.
2>Repair Operating System and data would be safe .
Jun 21, 2008 | Microsoft Windows XP Professional With...
Ntldr missing error
Ntldr is the Operating System bootup file. To boot into Windows, Ntldr file is must..
IF you have the Operating System disk with you, do the OS repair. This will resolve your problem...............
Sometimes, OS disk might be problematic, in such cases, you need to go with another disk to reload the Operating System.
Jun 21, 2008 | Dell Microsoft Windows XP Home Edition
NTLDR missing
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
May 24, 2008 | Microsoft Windows XP Professional With...
Maxtor Hard Drive Logo
73 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
