Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Ws-65313 no power unless it's unplugged first
My 65" mitsubishi will not come one unless i unplug it first for a few mins. Then it will work until i shut it back off, then i have to unplug it again for an extended period (guessing to disipitate the caps). Any help would be great.
  • jamesb69 Jan 23, 2008
    my dm board does not have the four caps on it that everyone is replacing. it only has the small silver button caps and they all appear to be fine. plus there are so many of them i wouldnt know where to begin replacing.
    Master:
  • 788 Answers
Could be a bad solder point that is disconnecting once it gets warm. I heard of people using heat guns to try to fix the solder points on XBOX 360 boards that get the three red rings of death with success, might work on your dm board.
Posted on Jan 23, 2008
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Weight of T.V.
According to a quick Google search, it weighs 325lbs
Nov 16, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Is there any way to split the tv in two pieces for
I do not see any way to divide main wooden box of TV as you can remove front screen and back cover of TV but main cabinet of TV still remain the same.
Check below exploded views of WS-65313 for better explanation.
Thanks.
Oct 30, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi 65in
try unpluging for 5 min then try again..this should reset it!
Nov 07, 2008 | Mitsubishi WS-65313 65" Rear Projection...
My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Mar 05, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
