Access Denied Dear All, I am facing Access denied error when i am installing my HP LaserJet 6L printer, this is happening after i have removed my printer for reconfigring previously it was working fine but now i am not able to install the same Please provide some help Regards, Shaikh Sufiyan
  • 167 Answers
Just see are you login as Administrator or try to install manually with driver which is digitally signed!
Posted on Jan 23, 2008
I share hp laserjet 1020 printer but when i shut down after start pc printer not access & unable to connect or access denied display occured on other pcs, what i do?
When you share the printer that is connected to your computer for other computers to use this printer, your computer MUST be left on at all times for the other computers to print to this printer.
The reason is, your computer acts as a print server, it collects the print data from the other computers and sends it to the printer.
Jul 10, 2011 | HP LaserJet 1020 Printer
Tip
How to solve acces denied issue while adding printer in windows server 2008
You might have faced access denied issue while trying to add printers in windows server 2008 using add printer wizard.see the pic below<br /><br /><br /><br /><img src="vahiddhm_0.jpg" /><br /><br /><br />To solve this, Right click on Add printer and select Run as Administrator option<br /><br /><br /><br /><img src="vahiddhm_1.jpg" /><br /><br /><br />Now you can install printer without any issues.You need to chose either local printer or network printer and continue<br /><br /><img src="vahiddhm_2.jpg" />.<br /><br /><br /><br /><br /><br />
on Jan 19, 2011 | Computers & Internet
Network installation error access denied on hp lj1020 my printer was working fine. i have installed printer on xp m/c its working fine but when i install it on win7 it give error print spooler error or...
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
Dec 19, 2010 | HP LaserJet 1020 Printer
Software won't fully install
Solution one: Run the Access Denied utility A utility is available that addresses access denied errors. This can be helpful for the 2203 error.
  1. Go to the HP Web site (www.hp.com) and in the search box, type AccessDeniedUtility .
  2. At this link:
  3. http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=oj-24444-2&cc=us&lc=en&dlc=en
  4. Click the Resolves "Access is denied" error during software installation link.
  5. Download and run the utility following the onscreen instructions.
  6. Re-install the software.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next solution.
Solution two: Re-register MSIexec service
  1. Click Start , then Run . The Run window opens.
  2. In the Open: line, type Msiexec /unregister .
  3. Click OK .
  4. Click Start , then Run . The Run window opens again.
  5. In the Open: line, type Msiexec /regserver .
  6. Click OK .
  7. Re-install the software.
Jan 06, 2009 | HP Photosmart 2610 All-In-One InkJet...
"Cannot install hardware. Laserjet 2840
HI,
First you have to check which operating system is used with your product? And download software from here . Then reinstall the printer driver again. After that if you face any problem let us know please.
Thanks
Chittaranjan
Jan 05, 2009 | HP LaserJet 2840 Printer
Unable to install
hi,
try to reinstall the printer using the laserjet driver instead of laserjet 6L. it's the remedy for that kind of problem..
rey
Sep 26, 2008 | HP LaserJet 6L Printer
Fatal error message
Hi all,
The error happens if your installation did not finish completely and you didnt have complete access and permission to the system(even though you are an administrator). Run the access denied tool by hp by clicking on the link http://tinyurl.com/5u2pg three times. uninstall the software and reinstall again. If this dosent work you will have to manually change the permissions in the registery.
hope this helps!
cheers
Aug 10, 2008 | HP Photosmart C4280 Aio Printer
Access Denied
This is a software issue. Sounds like it needs to be reinstalled but someone with password access.
Jan 23, 2008 | HP LaserJet 6L Printer
HP laserjet 6L
Get it cleaned in paper sensor area and check up the drivers as well as data cable which connects, the pc and printer. Change the data cable if necessary. Give me feedback so that may be some more help can be provided.
Mar 12, 2007 | HP LaserJet 6L Printer
302 people viewed this question
k24674
jasbo
jasbo
