Question about Baby Trend Snap-N-Go LX Double Stroller
Wheel need new front wheel
    Novelist:
  • 173 Answers
Click here
Posted on Jan 23, 2008
How to replace front wheel bearing
pull wheel remove grease cap undo carter key remove nut pull off rest of hub take bearings frt and rear out of hub clean old grease from bearings check bearing for defect install in revers order remender to install new grease in new bearings lots of grease and u will need new seals for same front and rear
Jun 14, 2014 | 2006 Suzuki Verona
New front brake discs fitting Colt GLX 1988 1.5 petrol manual
No, you shouldnt need to replace wheel brgs when replacing pads or even rotors . I beleve the brgs are in a sealed assembly and are only serviced when bad.
Feb 01, 2013 | Mitsubishi Cars & Trucks
How to replace front wheel bearing on 2003 kia sedona
Disassembly 1. Remove oil seal from front wheel hub. 2. Remove front wheel hub assembly with suitable tool.
bi6c021a.gif 3. Remove retaining ring. note_icon_eng.gif If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
bi6c021b.gif 4. Remove wheel bearing with suitable tool.
bi6c021c.gif note_icon_eng.gif Do not remove dust cover unless necessary. Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ai2a023c.gif note_icon_eng.gif Do not remove wheel hub bolt unless necessary. Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
bi6c021d.gif Assembly 1. Press in new wheel studs. note_icon_eng.gif Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
bi6c022a.gif 2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
bi6c022b.gif 5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
bi6c022c.gif note_icon_eng.gif Use a new oil seal, and apply grease to seal. Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
Jan 12, 2013 | 2003 Kia Sedona
Change a front wheel stud on a freelander
You need to take the entire wheel assembly off. The wheel stud will need to be pressed out of the hub and a new one pressed in.
Oct 14, 2012 | Cars & Trucks
I have Lionel 682 s2 turbine. Front axle and both front wheels are stripped. Wheels spin on axle. Need (2) 682-11 front wheels with boss. Need swaged front axle 681-18. Need (2) 681-23 center wheels. Need...
Your best bet is to take your locomotive to a Lionel Service Center. All these parts and diagrams are available but some special tools are required.
Oct 25, 2010 | Toys
My Phil & Teds Vibe shakes in the front wheel uncontrollably. Do I need a new front wheel?
Hi!
Assuming your tyres have the correct pressure, uncontrollable shaking in 3-wheeld swiveling strollers is usually caused by bearing slack.
Please check the front wheel bearing. It should allow the wheel to rotate freely but it should not be loose on the axle. (ie. It should not slide sideways on the axle.)
In this case you would need a new front fork/wheel assembly.
Please let a dealer have a look at it. As the Vibe has not been around for very long, you may still have warranty.
I hope this helps.
Erwin de Raad
www.babycare.nl
Oct 13, 2010 | phil & teds Vibe Stroller
I need new wheels for my Quinny Buzz
You can buy all the types of buzz wheels (front 3 wheel unit, front 4 wheel fork unit, front 3 all terrain air inflated unit and rear wheels) direct from Dorel, go to http://www.dorel.co.uk/contact-us/ or Tel: 01842 763281., they are always super helpful and very nice. Or you can buy them from this retailer (which I found to be a good deal cheaper) http://babyequipmentcomplete.com/main_site/main/index.php?pge=check or on ebay which are definitely more expensive for new wheels, but perhaps not for used ones. Hope this helps.
Apr 10, 2010 | Quinny Buzz Three Wheel Stroller
2wd front wheel need to replace bearings or hub assembly which is best
A Front Wheel Drive Vehicle Can Have Two Types Of Rear Wheel Bearings: Serviceable Bearings, Or Nonserviceable, Sealed Bearings. When Sealed Bearings Fail, The Bolts Holding The Bearing And Hub To The Axel Or Control Arm Must Be Removed. When Installing The New Bearing Assembly, Torque The Bolts To Specifications.Some Manufacturers require The Use Of New Fasteners When Rear Bearings And Hubs Are Replaced.
When A Serviceable Wheel Bearing Is Used, The Bearing Can Be Disassembled And Packed With Grease.It Is Serviced Like A Front Wheel Bearing On A Rear-wheel-Drive-Car.
Apr 09, 2010 | 2003 Ford Explorer Sport Trac
Changing front wheel hubs on a 2002 Toyota Solara - 4 cylinder
the rotors ? remove wheels and brake assembly and install new ones make sure to press the piston on the brake caliper or they wont go back on
Aug 24, 2009 | Toyota Solara Cars & Trucks
Baby Trend Snap-N-Go LX Double Stroller Logo
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
