Question about Harman Kardon AVR 225 Receiver
One speaker buzz when cold
I have a buzzing noise (bee in a jar) in my right front speaker and to a lesser extent in the right rear (smaller speaker) when I first turn on my receiver it has also had picture problems with the dvd player when I first turn them on. I have narrowed the buzzing problem down to the receiver itself through selectivly unpluging components, swaping speakers and wires,using a different wall outlet (both were well grounded). The sound doesn't change consistantly with the volume control but is slightly louder in the middle of the range and stops at the muted position.It doesn't go away with different surround selections.It gets alot quieter after the unit is on for 5-10 min.
  • schmoggles Jan 24, 2008
    I have essentially the same issue... I've had it for quite some time, but it comes and goes... I suspect either a failed cap or perhaps some ultra sonic crap oscillating in the power amp stages causing it go "motor boat". I just benched it yesterday and ran it un-loaded for a few hours, but of course it didn't happen.
    In the next few days, I'll hang a scope on it, load it, and have the heat gun and freeze mist ready to go. If I get anywhere, I'll let you know.
  • jones3435 Feb 28, 2008
    I was thinking it might be the filter caps for the power supply, then I tried un-pluging the video board ribbon and just as you said the noise went away. I might just use this receiver for tunes in the garage and get a new one that can switch the HD video.
It works fine for a couple of minutes the starts to hum. If you turn up the volume it masks the noise but is till audible, also the video switching cuts out. after examining the components I have seen some heat discoloration in the power suply area and believe it to be power for the video board. disconecting the ribbon cable form the video board the hum goes away, and so does any video wich does'nt matter for me because my monitorOne speaker buzz when cold - 1.gif does all the HD video1.gif switching. hope this may help with some noise problems.
Posted on Feb 06, 2008
  • 1 more comment
  • Mumrobs Apr 30, 2011
    I have the same issue! Very annoying.
  • dpollack317 Jan 02, 2012
    Un plunged the ribbon and no more buzz. I use HTMI now so the video is not needed any longer. Great easy fix. Thank you
  • Dave Hunter Mar 23, 2013
    This worked for me as well. Thank you!!!
I un plunged the ribbon cable and no more buzz. I use HTMI now so the video was no longer needed, Great easy fix. Thank you
Posted on Jan 02, 2012
I'm not sure why but since the last cold snap of -27 degrees here in quebec my montana SV6 has both cooling fans stuck on. The car starts fine and then after about 10 seconds after the start there is a...
I'm not sure the relationship, but if you have a rear heater A/C system in the van. The rear heater core and A/C components are located in the right rear. The buzzing noise sounds like a relay shorted, the buzzing is it rapidly turning off and on. It may indicate an electrical short in the heater A/C system which has a variance on the fan operation.
Jan 30, 2011 | 2007 Pontiac Montana
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Buzzing sound
does it ever give an error code? a common problem on whirlpool made machines is the dispenser arm getting caught when changing positions. This part is in rear of detergent dispenser housing and uses a motor and a arm to select detergent/ softner/ bleach/ and fill. you can remove top (screws on back) to watch this.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
There's always a bzzz sound coming out when plugged in.
if there's buzzing coming out, there's probably a rip in the actual speakers. Something is torn on the inside thus the weird buzzing noise.
Unless it was a zzzzzzzzz...... noise then there's probably some sort of interference. Possibly cellphone close by, or some other magnetic thing to create that annoying sound.
Apr 21, 2009 | Creative Labs SBS-260 Computer Speakers
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Rear speaker buzz!!!!!!!!!!!!!!!
i had the exact same problem which eventually spread to all speakers i took it to local repair guy, he was able to resolder the power board seem to fix all didn't really cost me much cheaper thean shipping back to spherex or whoever
Sep 30, 2007 | Spherex Xbox 5.1 Surround Sound System...
Speakers make a buzzing noise but wont play anything else
make sure that your system volume is turned up and that the speakers are turned all the way to the right.
Aug 22, 2007 | Dell A215 Computer Speakers
Rear Speaker problems
The delay is normal as it's designed to create a spacious large room sound. The buzz however, is not. It sounds like the power supply is bleeding into the amp and should be serviced.
Jun 01, 2007 | Aiwa NSX-DS55 CD Shelf System
Harman Kardon AVR 225 Receiver Logo
484 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
