I need to swap out the mode selection rotary switch on my S5100. Is there a diagram that details disassembly of this camera?
Thanks,
Andy
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
SOURCE: fuji s5100
http://www.rug.nl/rechten/voorzieningen/audiovisueledienst/productendiensten/handleidingen/finepix_s5500_manual.pdf
this is the link to where I found the manual for the fuji finepix s5100. it is a pdf file so you can save it to your computer.
SOURCE: need an owner's/instruction manual for Fuji finepix S5100 digital
hi there,
download user manual from here.
Thanks for using FixYa.
Good Luck.
SOURCE: My Fuji S5100 now fails to properly focus. I have
1 ensure that your camera is not set in Macro mode test by taking a
picture of a subject very close up ie. 10 - 15 cm if the image is in
focus then you may be set in macro mode.
2 if lens is removeable ensure it is fitted properly. remove the lens and refit ensureing the connectors are clean.
3 ensure the switch on the lens or camera is set to AF for auto focus.
4 suspect autofocus sensor is defective if you try to focus on subjects which are close and far away and you do not hear to camera re-setting the focus then it is in manual focus or the focus sensor may be defective or in need of adjustment.
5 recommend specialist have a look at this problem.
Testimonial: "I checked the manual and tried several solutions from the manual, still no joy. I used this service and the information provided sent me to the shop."
