Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven gas valve wont come on
I have a whirlpool gas range oven.i installed a new ignitor on the oven still will not work.I tested the new ignitor by switching it with the broiler ignitor and it worked fine.I suspect the gas valve is faulty as i cannot get any continuity at the valve.do you think that the problem is the gas valve???
thanks
brendan
  • langmc Jan 26, 2008
    thank you I appeciate your help.I will get a new gas valve .
    thanks .
    Brendan
  • 770 Answers
Your valve is bad replace it the ignitor needs to darw a min of 3.5 amps to open the valve if it is drawing the amps then the valve is bad
Posted on Jan 26, 2008
Ignitor isnt working
The oven ignitor should have a resistance reading of about 3.2 to 3.6 ohms. If the readings are out of this specification or show open replace the ignitor. measure the resistance of the oven valve. The gas valve should have about 1.5 ohms of resistance. If the gas valve is OK, the control board is suspect. The ignitor needs 120vac to work.
Apr 07, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Oven wont heat.
Checklist.
Glowbar: has continuity and is pulling 3,5 amps or better
Gas oven valve: has continuity between terminals
Oven control has continuity and is supplying voltage to the ignitor and valve.
Mar 04, 2011 | Whirlpool GW395 Gas Kitchen Range
Whirlpool Range Model # SF317PEYW1 oven fails to light. The igniter glows but oven will not light.
The ignitor, while glowing, may not be allowing the proper amount of current to flow through it to the oven gas valve for it to open. Proper testing requires an ammeter to check the current flow through the ignition circuit to the oven bake/broil valve.
Just because the ignitor glows does not mean it isn't bad. This is a common mis-conception.
If I were betting I would say your ignitor is probably bad.
Jun 10, 2010 | Kitchen Ranges
Oven wont light on whirlpool gas range
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor is inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Mar 31, 2010 | Whirlpool GS773LXS Kitchen Range
GE profile JGSP44 Oven stopped working
Ignitor needs to be working for the gas valve to open. If the ignitor does not reach the proper amp draw the gas valve will not open. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing an amp draw test on the ignitor.
Mar 28, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
Whirlpool gas oven-Super Capacity 465
When you turned the oven off, if the ignitor went off and the gas kept flowing then the thermal valve is defective. Maybe that was the problem all along.
Mar 20, 2009 | Whirlpool GS460 Gas Kitchen Range
The range on Whirlpool Super Capacity 465 will not ignite
You need to replace the oven ignitor. This is located under the bottom pan of the oven. Take out the racks and then remove the 2 screws from the back section of the lower plate. Then you will find the ignitor. The ignitor may still get red but the ignitor has to draw enough current to open the gas valve. This is a very common problem. Replace the ignitor and this will fix your problem.
Feb 06, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven wont light
there is continuity, you can tell that by the glowing ignitor, althoug otslooks like its glowing red hot, it need to pull a certain amperage to open the valve.i would reccomned replacing the ignitor.with 99.99 percent certainty
Mar 11, 2008 | GE JGBP28 Gas Kitchen Range
Whirlpool gas range
sounds like you have 2 problems the first the oven wont light is either a ignitor issue or a gas valve problem even though the ign. glows it may not be drawing enough amps to open the valve.it should be 3.5-5.2 amps at full glow.. have checked that? the over cooking sounds like a thermostat issue.not a lighting issue
Feb 22, 2008 | Kitchen Ranges
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
157 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
