Washingmachine leaks out the bottom
My washing machine leaks from bottom when it runs ,what do i do to stop the leak
  • carbo64 Feb 01, 2009
    how do I get to the inside hose of my whirlpool top load washer
  • 94 Answers
It could be a leak on the inside hose, but if its an old one it could be that the buket i rusted and falling apart if thats the case its bette to find a new one sorry
Posted on Jan 23, 2008
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
My Kenmore front loading washer machine is leaking. I open the front bottom panel and watched it during a washing. It seams to be leaking from the bottom of where the to halves of the tub(?) come together....
Hopefully its leaking somewhere else and just running down and dripping off the seam between the two halfs. If the seal between the two tub halfs is actually leaking you would have to completely dissassemble the unit very BIG job. Maybe take off the top lid and watch it operate hopefully you will find the leak up top...Good Luck
Sep 07, 2010 | Washing Machines
I have had my hotpoint washingmachine 4 about a year and a half and it is leaking from the bottom as soon as i turn it on please help?.
either a detached hose or hole in the plastic tank, check also at the rear that the heater is still fully attached... hose is ok to sort tank is more serious.. good luck
Dec 18, 2009 | Hotpoint Washing Machines
Washing machine leaks from front top 3 lines run from top to bottom
The water mixing valve is gone bad, replace valve this should stop problem Hope this may help.
Jun 02, 2009 | Washing Machines
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Top load washer.
Hello rschneeweis
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
you pump is leaking most likely you will need to remove the cabniet to check this and run it with it off to find out for sure
Feb 16, 2008 | Washing Machines
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
