Question about Panasonic Lumix DMC-LZ2 Digital Camera
My screen is black. Can you help me?
The screen is black but the menu and functions will appear on it. Everything appears to be working even the flash. It just doesnt show a picture of what I am photographing.
  • 3 more comments
  • rockrules925 Feb 07, 2008
    My screen is black with an exception for previous pictures Ive taken and all of the menue fixings. Lots of people are having this happen. what do we do?
  • doubleup Feb 21, 2008
    I too am having this problem. My camera shows past photos fine & all the menu/display is working...but the view finder screen is black & all new picture taken are black too. It happened a few days ago, but went back to normal. Today it stays black! Help!!! My daughter is learning to crawl & I NEED to capture these moments!
  • ashleybt Mar 11, 2008
    Screen is black, all functions work besides that
  • Anonymous Mar 12, 2008
    Mine worked fine yesterday and today has a black screen. All the old pics are there, but nothing I do today will show up at all.
  • Anonymous Mar 13, 2008
    I'm having the same problem. It was fine one minute, and not it's just black, no matter how bright the subject is. Flash and menus work fine.
Mine must be a different model than yours, since the card doesn't touch the cover.
Posted on Mar 14, 2008
Found a very useful recommendation on:
http://www.fixya.com/support/t136499-black_screen
This corrected the problem!!
The hardest part was getting the metal bracket for the SD card holder back in place. It needs to attach to the back cover first before snapping the back cover in place.
Posted on Mar 13, 2008
6ya staff
SOURCE:
Lg w2343t monitor
try monitor on a different working desktop to see if it works, both on the external and internal video card ports. If screen menu buttons fails to respond, fault is either on menu buttons or you may have a burned out lcd screen, try a different monitor on your desktop pc to check its functionality. Monitor probably needs replacement.( It might not be burned out for you mentioned "no signal" error message appeared on screen, have the screen menu buttons checked)
Dec 28, 2013 | Computers & Internet
Hi, I have a Canon T2i Rebel. When i put the camera in "M" (totally manual), the image doesnt appear in the LCD screen. Everything else works fine in the monitor, but it is as if the lens where...
That's great news, so let's write it up as a solution so that other people who search on here find the right information!
So it appears that the Canon T2i when in manual mode (M) remembers whatever settings you play with, and that these settings are remembered across power cycles; in other words, turning the camera off, or switching to auto before going back to manual does NOT put the settings back to a default.
This gives you the opportunity to set choices that make the screen view totally white or totally black, and unless you realise what you did, you can fear that your camera is broken in some way. At first, I thought this was a user interface flaw, but at least with the screen black or white, you know which way you need to go to get your picture back! The settings that affect brightness are Shutter Speed, Aperture Value, and ISO Rating. They are accessed in manual mode with the thumbwheel, alone, with Av, and after pressing the ISO button, respectively.
One more little bit of trivia: when in manual mode if you don't have live view on, when you half press the shutter, a little indicator comes up on the exposure scale, so that you can see how the settings you've chosen are going to come out.
P.S. I noticed that there was a forum especially for your camera, you might like to join it, it's called t2iforum dot com.
Jan 24, 2011 | Canon EOS 550D Rebel T2i Digital Camera
All of the icons from the screen disappeared!
try to reboot your computer into safe mode.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Then click start
click run
type in msconfig
uncheck everything under the startup tab except your antivirus
and reboot
Jun 05, 2009 | Computers & Internet
Start Menu & Taskbar do not appear
How are you accessing Control Panel without a Start Menu or Task Bar? You may want to check/adjust your screen resolution in Display Settings.
Apr 19, 2009 | GE Computers & Internet
Sony DSC W40 , screen appearing black
ther should be a small button below the menu botton try pressing this a few times this a energy saving device .hope this helps.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Black menu-like box randomly appears, covering the picture
This is a problem with closed-captioning. What you are seeing is a closed captioning box with no captioning in it. Usually this is being accidentally transmitted by the cable company "head end". Just make sure your closed captioning function is completely turned off. if you are seeing it randomly, it may well be coming from your cable company. Is it just on certain channels?
Sep 05, 2008 | Toshiba 15DLV76 Television
I had a similar problem, but in my case teh screen was not entirely black but the image was very dar, like someone shut of teh lcd backlight, but the photos were coming ok (when checked on the pc). Showed it at repair sho, abd found out that one of the pcb supplying power to the backlight was not working and had to be replace. couldn't do much at home.
Apr 03, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Black Box
Hi Krautner, We have a Toshiba and experienced the same problem this morning. It is very similar to your symptoms: big black box in centre-lower part of screen. It sometimes disappears momentarily when you select a feature such a "mute" for the same amount of time the screen displays that function. Once the "mute" signal disappears, the black box comes on again. I fixed the problem by turning off the close captioning function. Somehow, it had actually got switched on. It runs fine now. I suppose you have already found a fix since you posted back in May....but hopefully this helps you or someone else putting in a similar search for this fix. Cheers Geo
May 09, 2007 | Toshiba 46HM95 46" HDTV
Panasonic Lumix DMC-LZ2 Digital Camera Logo
345 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
