Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Size of the picture decreased
Wonder why the size of the picture on the 34in. tv is no longer of the standard size. It's smaller now. We tried adjusting by looking at the manual but it didn't work.
Pls email me :
  • lisa2003 Sep 13, 2008
    Every time my TV is on SKY it automatically adjusts the picture size. I then adjust it ti WIDE screen but then about every 10 mins it goes back to 4:3. This is extremely annoying please help??
  • 43 Answers
If this only happens with your cable or satellite box this may be an adjustment in your box. So you may need to contact them and find out how to adjust the picture size. This tv may have a wide mode setting on the tv remote. Pushing this button may select full,wide,wide zoom or normal size. On many occasions the tv stations control the picture size. Good Luck
Posted on Jan 23, 2008
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
Feb 05, 2015 | TruTech PVS31170S1W 17 in. LCD Television
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
The screen seems like its fixing to go out! The picture starts off normal size then gets smaller and almost goes completely away!
when picture is getting smaller in size or goes away then hit your TV lightly on left side or right side or on top & then observe will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some CRT computer monitors & CRT TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size & disappears...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked your case iam sure it is loose connection problem.........joints should be re- soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other contact good TV service engineer
Apr 16, 2011 | Disney DTD1363-CAR 13" TV/DVD
The Tv screen is much smaller during video games than what it is during Movies. Please Tell me how to adjust my screen size.
Movies are shown at a higher resolution than games. That is why the picture is smaller with games than movies. If you turn the Auto Picture Size off, you can set lower grade video to a larger screen size but you will lose quality.
Hope that helps.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
My picture is smaller than screen size..
the only thing I can tell you is go to menu and check for screen size or what else fails read the manual
Nov 16, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Shrinking picture file sizes
Use image editing software to reduce the physical dimensions, and the resolution, to decrease the file size.
Jul 29, 2017 | PANDIGITAL (DPF802) Digital Picture Frame
Random ARC Picture Size Change
What Brand TV do you have? What cable box are you using?
Dec 07, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
480 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
