Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Tv toshiba vertical problem
Tv show a vertical line
  • 2 more comments
  • Anonymous Mar 05, 2008
    ligne vertical
  • Anonymous Apr 29, 2008
    Has vertical white lines about 8 at the top of the tv
  • sasanders36 Jul 16, 2008
    i had the same problem a loud pop and no picture the sound is good.
    i hope someone can help.
  • elsabalero88 Jan 09, 2009
    my tv picture is split in half vertically, does anyone know what i should do?
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Posted on May 15, 2008
My tv picture is split in half vertically, does anyone know what i should do?
Posted on Nov 01, 2008
    Problem Solver:
  • 15 Answers
It's the Vertical Output Transistor that has gone bad. Parts may be available online with Mouser Electronics, or Digikey
Posted on Oct 17, 2008
  • Sam DiBaise
    Sam DiBaise Oct 17, 2008
    I would check the horizontal output also
  • MIKAEL Dec 05, 2012
    VERTICAL IC OF ONE KONKA TV BECOMES HOT AND AFTER 20 MIN MAKES IT OFF.I HAVE SEEN THAT COMPONENTS ARE OK. CAN YOU GIVE ME AN IDEA.
I get a color show of vertical lines on my regza 46rv53cu tv what could it b
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 28, 2015 | Toshiba Televison & Video
I have horizontal lines running across a two to three inch section at the top of the set. Is there a way to fix this? Maybe a way to ajust the vertical sink? These lines show always regardless of video...
From your description it sounds like a vertical problem, the IC in the vertical sector may need to be resolded or replaced, there are 2 or 3 capacitors that should be checked that are very near the IC. This is a very common problem with Toshiba sets, and are worth getting repaired.
Dec 20, 2010 | Toshiba 27D46 27" TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Toshiba 27AF44 shows vertical lines and crakles very loud
The capacitors at the vertical stage must be faulty resulting in the above symptoms.
Sep 20, 2008 | Toshiba 27A44 27" TV
TV: vertical colored lines on TOSHIBA TV Model 36ZP46P
HAI,1.REPLACE SOME CAPICTORS IN HORIZONTAL SECTION.
       2.ADJUST FOCUS ON LOD(EHT TRANSFORMER).
       3.REPLACE HORIZONTAL OUTPUT TRANSISTOR.
Jul 05, 2008 | Televison & Video
Vertical Deflection
check soldier connections on vertical i.c.
Mar 13, 2008 | Toshiba 30HF85 30" TV
Toshiba 32 SDTV
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 23, 2008 | Philips 25PS40S 25" TV
Toshiba 30" CF0C50
You have a bad capacitor in your vertical area.
Dec 29, 2007 | Toshiba 27A34 27" TV
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 46HM95 46 tv
If the line is all that is showing with black on the top and bottom. This indicates a loss of vertical deflection which is caused by the loss of the veritcal sweepignal. Check the output of the vertical section of the TV set. You will need an oscilloscope, and multimeter along with a schematic.
Oct 01, 2007 | Toshiba 46HM95 46" HDTV
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
297 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
