Question about Zenith B27A11Z 27" TV
Zenith 27inch B28A11Z keeps powering itself off
My Zenith 27inch B28A11Z keeps powering itself off. When I first turn it on it makes a popping sound sometimes for 5 minutes before it will act like it is trying to turn on. Then eventually it will come on, but may turn off every few minutes at times. Then other days it stays on for hours(not lately), but it is getting worse.
Any solutions, could it be something simple like a fuse?
    Problem Solver:
  • 15 Answers
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
Posted on Jan 23, 2008
Turn signals and flashers
The flasher itself is toast. It’s mounted in the in cab fuse box. Looks like a small cylinder, usually silver metal or black plastic. Pop over to a parts store, usually about 5 bucks.
Dec 14, 2017 | Chevrolet Suburban Cars & Trucks
Samsung LN 32C 530F1F keeps powering off randomly
probably overheating. hoover out the vents and make sure plenty of air can circulate. a case of suck it and see. lol
May 24, 2017 | Zenith Televison & Video
My gateway 510x keeps shutting itself off. Sometimes after 5 minutes of booting up sometimes after 30 seconds. What could be the problem? Tried removing dust from the inside but that did not help.
sounds like your processor fan shut down and now your processor itself shuts off when it begins to over heat replace fan asap and don't keep trying to turn it on because you'll burn it out
Mar 31, 2010 | Gateway 510 X PC Desktop
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Sep 14, 2009 | Zenith R56W36 56" Rear Projection...
Profile 5 shuts off on its on
Sound either like a Overheating or a Power Supply Unit issue. You may need to clean the thermal gel off the CPU and heatsink with a small amount of rubbing alcohol and apply new gel. Make sure your fans are working correctly and make sure there isn't any dust under the fan on the heat sink it self, as this will cause overheating issues... Also, if you suspect the PSU you can usually get a nicer one than you have now for $50, so it is better to go ahead and replace it if it is old. The pop sound makes me lean more towards the side of power / PSU but this sound could simply be from the hard drive lossing power suddenly.
Dec 11, 2008 | Gateway Profile 5 PC Desktop
TV turns on at odd hours by itself
Hi, I had the "Ghost In The Machine". I tried out what I descibed in my original posting.
#1. I unplugged The Set.
#2. I pushed in and held in the power button in for about 5 minutes before bedtime. ( The PC trick I learned) I gave it 5 minutes because a tv set has much more power inside it.
#3. I again pushed in and held the power button in again for 3 minutes the next morning.
#4. I plugged the tv in again. The red standby light was lit. The set did not immeadiatly come on when I tried to power it up.
#5. 5 Minutes later I returned and hit the power button on the remote and it came on like nothing ever was wrong.
#6. It has been fine now for 3 days!!! Powers up when commanded and shuts down like normal. It has yet to come back on or act up as it was doing.
I will keep a watch on it and if it starts up acting again I will repost. I hope this information will be of use to anyone who experienced the same problem. It didn't cost a dime, just some patience. Thanks for a forum that people can exchange information and save trouble and money unless all options are exhausted. Bill
Mar 09, 2008 | Philips Magnavox 20MS3442 20" TV
27" GE TV with loud Popping sound
Could be a possible flyback. yes.. for a 27inch i would not think it would be worth it... 27 inch tvs are realativly cheap.. the lowest price to repair would be about 200 if you got lucky.
Dec 18, 2007 | GE 27GT271 TV
Zenith Plasma Z50PX2D turns on by itself
yes;and my controls rarely work unless it is kissing the unit.I also find it difficult to change the channels manually.[BOBBY](512)
Oct 11, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Zenith B27A11Z 27" TV Logo
116 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
