Question about Fuji FinePix 2600 Zoom Digital Camera
Replace Battery Cover
I need to replace the battery cover on my Fuji FinePix 2600 camera, which is broken. I can't figure out how to get it off. It is held in place with a metal pin.
  • 5 more comments
  • tkfun1 Jan 24, 2008
    Yes, I have the replacement cover. When I went to replace the broken cover, that is when I realized I couldn't figure out how to remove the broken one.
  • tkfun1 Jan 25, 2008
    Ok, I got the back cover off (and it does have a ribbon cable attached). But I am still unable to remove the metal bar holding the battery cover in place. The bar is between two holes that are in a solid piece of plastic and there doesn't seem to be enough give to be able to remove the bar. Also, I have tried pushing down on the end of the bar in case it was spring loaded like on watch bands, but that didn't work. Am I missing something here or not applying enough force? I just don't want to break it and make matters worse...
    cammedic, thank you so much for your help. You're awesome!! It didn't even dawn on me to try and pull the pin out. My needle nose pliers were not small enough, but tweezers did the job.
  • Jay Scott Apr 28, 2008
    Same problem... cover cracked around latching protrusion on center
    outside edge. Only a matter of time until it breaks off completely.
    Seems a simple fix, although the only replacement cameras I've seen so
    far are around $50... Ouch... for a 2MB camera, that's a bit steep on
    a replacement part...
    Anybody got a line on some less expensive replacement battery doors?
  • Anonymous Jul 08, 2008
    FinePix 2600 Zoom Digital Camera battery cover replacement
  • Dennis Chandler
    Dennis Chandler Mar 06, 2009
    How do you remove the pin hinge to replace the battery cover on a Fuji 2600? Thanks, DC
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    have you acquired the replacement battery cover?
  • 667 Answers
Separating the front and rear covers of the camera is not that difficult. You'll need a good small cross point screwdriver. I do not have a 2600 in front of me, but the 2650 is similar. Remove all the screws around the sides of the camera. The top sections are snapped together. work along the back edge to undo the snap tabs. I do not remember if there is a ribbon cable attached so go easy when you remove the back half.
My chat is not working yet, so if you want to go this far, let me know
Posted on Jan 24, 2008
  • Kevin Pettit
    Kevin Pettit Jan 25, 2008
    You have to drive the pin out toward the back of the camera. (I am still using a 2650 for reference) I just tried it by grabbing the middle of the pin with needle nosed pilers and it pushed right out.
Battery cover clips broken
I had the same problem with mine, sent mine to Fuji for repair.
Unfortunately they no longer have parts for this model, 8-(. I simply had to resort to using tape to keep the cover closed.
Jan 25, 2014 | Fuji FinePix S5500 Digital Camera
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
I need Battery Compartment Cover for .Fuji FinePix 2600 Zoom Digital Camera The catch over the batteries has broken off.
proove to fiond it on ebay international seller is possible that you find in the world only the catch or it s possible that you find a entire faulty camera..and disassemble the catch form the camera..
i hope that i have help you. sorry for my english
Aug 10, 2010 | Fuji FinePix 2600 Zoom Digital Camera
My fuji finepix 2600 cam is simply eating all the energy out of fully loaded, new batteries. Nothing wrong with the loader. Is the cam destroyed or what ?
Digital cameras are high drain devices, regular batteries finish fast, need to use alkaline plus batteries; also take out batteries out of the camera, when not in use.
Oct 10, 2009 | Fuji FinePix 2600 Zoom Digital Camera
Broken cover on a Fuji FinePix S5000
I think it will stay closed with painters tape or gaffer tape. this type of tape is blue or black. it is strong but not super sticky. I also have the same camera. my battery cover broke after the strap got stuck on a door handle to my office and the door kinda crunched it.
Apr 05, 2009 | Fuji FinePix S5000 Digital Camera
How do I replace the battery cover
There is a little spring latch on the larger of the 2 metal components, (the one mounted to the body) on the cover. Raise this gently and the cover just slips off. A replacement can be bought from for about $10. Fuji wanted £97 to do this!
Jun 29, 2008 | Fuji FinePix S7000 Digital Camera
Battery cover
I had a look at my S5000 and see what you are talking about. Those tabs are part of the inner shell, likely expensive to replace if even cost effective. In the past, I have cut the broken tabs off, leaving a flush surface. I then drill small holes and insert large head screws that I file to match the door tabs. It does require some finite work but is possible without disassembly of the camera.
Jan 22, 2008 | Fuji FinePix S5000 Digital Camera
Battery compartment cover
They really want you to buy a new camera instead!
TAPE it shut!
Otherwise you can sometimes find equipment sold 'as-is' for parts on eBay or other internet sites.
Do a web-search for it.
Nov 01, 2007 | Fuji FinePix S602 Zoom Digital Camera
Fuji FinePix 2600 Zoom Digital Camera Logo
316 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
