Question about Kaito KA1916 Shelf System
My turntable on my ka1916 is running slow
I have a Thomas pacconi model tpc-mse-800 and the turntable is dragging. At first I thought irt was the belt and I ordered a new one. The belt was bad as there is a fairly big difference between the new and the old. yet when I replaced it the turntable still runs slow so now im convinced that the motor is the culprit but I can not find a replacemant motor based on the numbers on the motor housing. it is a mabuchi 12 v motor part number# EG-520SD-2F with an rpm range of 130-1520 rpm I sure would appreciate any assistance in getting this thing going again
  • Anonymous Aug 21, 2008
    I have the same motor but the motr is loading down the 12 volt supply ,need source of getting the motor
  • Anonymous Sep 27, 2008
    I have the same problem with similar units that use the same motor ,im trying to locate a source for these motors EG530SD-2F,does any one know where i can get them Use In Curtis Stereo s and Emerson Stereos Model # NR305TTc
2 Suggested Answers
  • 5 Answers
SOURCE: My Thomas Pecconi TPC MSE 800 cassete player
A similar unit arrived for servicing. In this case, a poor solder job at the point where the red and black wires connect to the motor was the problem.
Posted on Aug 13, 2010
I have a Thomas Pacconi Model TPC-MSE-807 turntable. The Power/Volume Control has gone on it.
Look on the data plate to see if there is a voltage and current draw value on it. The switch should be rated at 120 Vac @ 10 A.
Feb 02, 2017 | Dual Audio Players & Recorders
How can i repair my radio that seems to get no power when i turn it on
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the unit and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 06, 2014 | Audio Players & Recorders
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
Thomas Pacconi Model TPC-MSE-800 turntable runs slugglish. 78 runs fine but 45 or 33 runs slow. I removed belt cleaned it and platter. I put a drop on oil still same problem. Do I need a new belt? This is...
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Dec 16, 2010 | Seth Thomas Pacconi Turntable
My Thomas Pecconi TPC MSE 800 cassete player stopped working - please advise troubleshooting tips
Jul 08, 2009 | Kaito KA1916 Shelf System
Thomas Pacconi turntable turns too slow
My older Thomas Pacconi turntable was also turning too slowly. Rather than replacing the belt or needle, I tried using an eye glass repair screwdriver to alter the trimmers inside the motor. But the changes didn't take. Then I tried trimming the power to the motor using the larger trimpot next to the motor with the motor itself set to the 78 rpm setting. But the adjustments to the trimmer didn't get the platter to spin slow enough - it wouldn't play an LP. To get the speed down further I replaced the 1K trimmer with a 10K trimmer I picked up for a buck at Radio Shack and successfully adjusted the turntable down to down to 33 1/3 rpm usage. All that was needed was a soldering iron and a 10K trimpot to get the job done.
Dec 28, 2008 | Seth Thomas Pacconi Turntable
Kaito KA1916 Shelf System Logo
1,071 people viewed this question
Top Kaito Audio Players & Recorders Experts
Level 1 Expert
xxxxxx xxx
Are you a Kaito Audio Player and Recorder Expert? Answer questions, earn points and help others
