Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Dirty Screen How do I remove the screen protector to clean behind it?
  • TERESAB526 Jan 22, 2009
On the Philips 51PW9303 51 in. the Front panel just snaps off from the front. just five it a little pull from one corner and it will come off. I clean mine about once a month.
Posted on Jan 24, 2008
  • Philips Master
  • 8,617 Answers
You should be able to access the screen from behind after taking the back panel off.Also if you reach up inside the rear wall you can clean the mirror ad picture tube lenses. This will make a vast improvement on picture brightness and quality.
Posted on Jan 23, 2008
Iphone 4s shins
Step 1: Clean your workspace. Be sure to get a flat, hard surface without a lot of fabric, liquid, dust, etc.
Step 2: Lay the phone down and clean it well with the cleaning cloth provided. Do not use any kind of cleaning fluid or water, but try to be sure that all fingerprints are gone. Especially be sure no dust or lint particles are on the screen. Before proceeding be sure that there are not a lot of dust particles gathering near you, vaccum and clean the area up a bit more if need be. You want as sterile an area as possible before continuing.
Step 3: Being careful not to touch the sticky side of the screen protector, peel back the tab where indicated. Hold the screen protector only by the sides and line it up with the phone. If you touch the sticky side of the screen protector by accident do not try to clean it off, you will only make it worse. Line up and let the screen protector fall into place from the top of the phone to the bottom. Some people choose to use a credit card or thin piece of plastic to smooth out bubbles as the screen protector makes contact with their device, however this is usually not recommended by the makers of the screen protectors or the phone. The choice is yours, but bubbles are meant to smooth out over time, so take that into consideration.
Steap 4: Once the screen protector is on the device if it is straight and you can see bubbles but no lint or dust beneath it, you are successful, give it a few days for the bubbles to dissipate. If it is not on straight, you may be lucky enough to be able to lift it up and place it better without fault, however this is risky. If lint or dust has gotten between your phone and the screen protector you have likely failed, there is little recourse from here, other than removing the screen protector, cleaning the device, and trying with a new screen protector altogether.
May 24, 2013 | Cell Phones
To prevent inevitable iphone 7 LCD Screen damage and avoid repair costs, invest...
To prevent inevitable iphone 7 LCD Screen damage and avoid repair costs, invest in phone cases and screen protectors for your iphone 7. Screen Protectors Made from tempered glass, screen protectors safeguard your phone against scrapes and scratches without compromising touchscreen sensitivity or image quality. Phone Cases There are many stores make durable phone cases and covers to provide extra security for your iphone 7 and protect it from scratches, drops, and dust. A good Clean Because your iphone 7's screen is the interface of the device, it is bound to get smudged and dirty quickly from the time spent using it. When cleaning your screen, never use a chemical cleaning solvent. Instead, use water and a clean, lint-free, scratch-resistant cloth, such as microfiber. Dampen the cloth-not the screen-and gently wipe off with even strokes.
For Apple iPhone 7 LCD Screen and Digitizer Assembly with Frame...
on Apr 13, 2017 | Electrical Supplies
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Screen touch not working
Clean the touch screen on the phone with an electronics cleaning cloth or wipe. Dirt, dust and oils from your fingertips can collect on the screen, making it unresponsive or desensitized to your finger's touch. Clean the screen in a circular motion.
Eliminate any bubbles under the screen protector. You can do this by removing the screen protector and then reapplying it, going from the top of the screen to the bottom or vice versa.
Remove the screen protector and do not place the protector back on the touch screen. Screen protectors are made for protecting a touch screen, but sometimes the protectors make the touch screen less responsive to your finger touch or even altogether unresponsive.
Power off the touch screen phone if the touch screen stops working when a new program is opened. This isn't a problem with the touch screen, but a problem with the software trying to load or open on the phone. Some programs can slow response time with the touch screen or may not respond to it at all.
Mar 03, 2011 | Samsung Star GT-S5233 Cell Phone
Cleaning tv screen protector cover
Mar 07, 2009 | Televison & Video
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Dark blotches behind the screen
When I had this problem with my 52525 I cleaned the bulb with a lint free cloth. The dark blotches went away.
Dec 28, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Inside the cabinet projected on the screen?
well . there are 4 things that can cause this..
1= the outer screens could be dirty.clean with screen protector cleaner.Spray on cloth and not on outer screens.
2= outside lenses of picture tubes could be dirty.Unit can be opened .Outside lenses can be cleaned with a lens cloth .Do not use paper towels or cotton as this my scratch surfaces of lenses.
3= inside of picture tubes could be dirty.This should be done by a repair shop only(dirty coolant inside tubes)
Dec 28, 2007 | Philips 55PP9401 55" Rear Projection...
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Touch screen problems
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend. ============================================= Touch Screen doesn't respond or is inaccurate when touched * Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen. * Use only licensed Nintendo DS styluses and screen protectors. * Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens. * If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen. * If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen. If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
Jul 20, 2007 | Nintendo DS Console
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
