Question about Bosch 24 in. SHV57C03UC Built-in Dishwasher
Dishwasher was damaged
A person fell on the door when it was open and dented the metal on the door. There is a bulge where it meets the gasket. Also the hinges are not operating smoothly. Will the dishwasher function. How can I tell if it will work now. Is this something that I can fix?
  • 51 Answers
Yes, you can fix it. Go to www.repairclinic.com and look up the model number of your d/w, select the parts that are damaged and you have a new d/w.
Have fun.
Posted on Jan 23, 2008
Leaking dishwasher
The rubber strip that the door connects with is crudded up with junk. Get rag and hot water in bucket. Open door. Look for rubber gasket shaped like an upsidedown U, the sise of the door. It wont be black in places because of all the build up of soap scum. Wash this off till it black again. Wash door where it meets this gasket.
Good Luck.
Jan 11, 2014 | Frigidaire Dishwashers
Purchased scratch and dent kenmore electric range model 96419. Did not see when I looked at store that the handle was broken, also the door does not want to stay shut. I close it and the door pushes...
not all scratch and dents are plug and play yours sounds like it was dropped or received a damaging blow you will need to look for door replacement parts and possible alignment of door or body frame
May 30, 2017 | Kenmore 96412 / 96414 / 96419 Electric...
Leaks at right front corner
Open door and check seal, make sure there is no damage, tears etc. Also check the door edge that meets the seal for damages, make sure the door is operating correctly(hinges ok). Good luck, best regards. .
Feb 02, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
My Refridgerator's door is tight.It can not open easily.
Wax the metal part of the door where the rubber meets it. Put some silicone spray on the rubber gasket ... dont go crazy with it. Spray on a rag and wipe it on with the rag.
Jul 31, 2010 | Refrigerators
KitchenAid KUDM25SH sprays water from under door at start up
Make sure the area where the door and bottom of the dishwasher meet there is not a buildup of debris. Inspect the dishwasher's gasket and make sure it's intact. It is pretty common to need to replace these. Finally, unscrew the little service door on the bottom of the machine and stand back and watch it for an entire first cycle. It might be squirting out of a slightly cracked pump housing that only leaks when subjected to the stress of startup, the water valve could be leaking when it opens to fill machine, or something else could be leaking. Make sure the wash arms are not damaged, are rotating freely, and don't have anything stuck in the jet holes.
Sep 19, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
The rubber gasket around the tub fell off on front loader
Open the door and reinstall the bellows (door gasket) onto the door lip. The metal ring clamps the bellows to the door lip. Start in the groove at the top and work your way down the sides. The spring part goes on the bottom (be careful not to stretch it too much). An extra pair of hands could help.
Let me know if you need more assistance.
Apr 02, 2009 | GE Washing Machines
DISH WASHER, STILL HAS A LEAK FROM THE DOOR.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Servicing the Door Latch
The latch on a dishwasher door is opened and closed repeatedly, and this hard use can lead to mechanical problems. The latch may be loose, or it may have slipped out of position, throwing the alignment off and preventing the door from closing properly. When this happens, the latch does not engage properly, and the dishwasher will not start.
In many cases, you may be able to solve the problem by adjusting the position of the latch. Move the latch slightly by loosening the screws that hold it. Slide the latch with your fingers or pliers; the screw slots are made especially for this purpose. Close and open the door to see whether the latch is properly aligned. Tighten the screws to hold it in the correct position.
After repositioning the latch, check to see if it's working properly. Close and latch the door and turn the control knob to the ON position. If the dishwasher doesn't start, the latch is faulty. Replace it with a new latch, connecting it the same way the old one was connected. You may have to move the new latch back and forth several times before it works properly.
PLEASE mark this answer as a fixya! thanks
Dec 26, 2008 | Samsung Digimax A503 Digital Camera
MAYTAG JETCLEAN QUIET PACK
hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Oct 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Bosch 24 in. SHV57C03UC Built-in Dishwasher Logo
110 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
