Question about GE WHRE5260E Top Load Washer
GE WHRE5260E1WW Washer
After filling tub for either wash or rinse, small amount of water still runs into washer tub.
  • Anonymous Mar 29, 2014
    When My washer starts to fill with water, it leaks out from under the bottom of the machine
  • 51 Answers
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
I have a ge tl washer model number whre5260e1ww and it's not rinsing all the suds out. One day I rinsed the same load of towels 9 times and still had suds. Any ideas?
How much soap did you use? During the final spin, your "final rinse" lets water into the tub to rinse out any remaining soap. Check to see how long it rinses for. If it is very briefly (a few seconds), there might be a problem with the timer or the electronic water inlet solenoid. The solenoid is what opens the valve to let the water in. Sometimes when they go bad, they won't let the valve stay open long enough to let enough water in.
May 11, 2012 | GE Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Hiw many gallons of water with 2 rinses does a top
Your washer takes 35 gallons to wash and 35 gallons to rinse. Ask me how I know? Well I work on them but last December my washer (which is the same as yours) developed a problem with the cold water inlet valve. My inlaws and daughter and friends all come by at different times to use paws paws washer. They pass 50 laundry mats to come to my house. Just for fun I told my wife to get a 5 gallon bucket and fill the washer up. It takes 7 buckets to fill the washer up and get it to start washing. Later she decided to run a water hose out to the washer and fill it up. Then my mother in law suggested she put the washer on rinse and fill the tub. That told me I had a timer problem. But luckily I have 2 or 3 washers around the house I can get parts off of. So to recap: 70 gallons of water to wash a full load of clothes is what I guesstamate it took. Did that slow down my inlaws? Nope.
Mar 05, 2010 | GE WHRE5260E Top Load Washer
Ge model wbse2090a washer over fills in the rinse cycle
Clogged pressure switch hose at the tub on left front side of tub pull off and use a small screwdriver or a pipe cleaner to clean.
Feb 22, 2010 | GE WBSE2090A Top Load Washer
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Water level adjustment
You don't. Front load washers use only a very small amount of water. They fill a small amount, tumble a bit, resulting in water being absorbed into the clothes, which drops the water level in the tub. The washer senses this and adds more water, which repeats until water level stabilizes. The only way to get more water on wash cycles is to use delicate cycles, which use more water, resulting in a more gentle wash action. Remember that due to the low water consumption of front load washers, you should only use one tablespoon of HE detergent per cycle. (even less if you use 2x or 3x concentrate.) This is a FixYa solution. Your washer is working as designed.
Oct 23, 2008 | Whirlpool GHW9100L Front Load Washer
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Water level
The level of water in the drum is controlled by a pressure switch. This switch is attatched to the drum via an air tube which pushes air into the pressure switch as the machine fills with water. There could be a blockage in the pressure chamber attatched to the drum or the pressure switch is faulty.
Oct 31, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WHRE5260E Top Load Washer Logo
623 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
