Question about Lexmark Z1420 InkJet Photo Printer
Lexmark Z1420 cartridge reset - Lexmark Z1420 InkJet Photo Printer
  • 1 more comment
  • jhersh Feb 01, 2008
    When I go to maintence in the solution center and choose "install a catridge" it walks me through physically installing it and then asks me to print a test page, but then when I press print it says "Black Cartridge Replacement Required" "Please install a new Lexmark cartridge or oreder a new cartridge from Lexmark." "Follow these steps to replace the black cartride in your printer 1. Cancel printing. 2 Replace the black ink cartridge. 3. Resend the print job. A variable amount of ink will remain in the cartridge. You may use the Complete-A-Print option to print using only the color cartride" If I check "Complete-A-Print" it will print but without using the black cartridge. I have uninstalled and re-installed the printer twice and clean the cartride multiple times. Do I need a reset tool? Is there someway to make this printer see this cartridge as a new one?
  • Anonymous Mar 17, 2009
    absolute ******** from *** mechanic688
  • ilangford May 11, 2010
    Sorry Mr. Mechanic688, but there is no "reset" or cartridge maintenance tab on the driver and software that comes with the Z1420. I have spoken to Lexmark Tech Support and they have acknowledged NO REFILL kit will work with this printer nor for that matter any cartridge that is not a Genuine Lexmark cartridge. We who got sucked in to buying this cheap wireless printer are stuck paying exhorbinantely high ink cartridge prices with very little ink in them! Bummer! Last Lexmark I will buy!
  • 204 Answers
On my lexmarks, the cartridge resets are on the Lexmark tab in the programs menu after hitting the start button. They are in with the cartridge maintenance tab. This all comes from the software download. I hope this helps you,, Mechanic
Posted on Jan 23, 2008
5 Suggested Answers
  • 390 Answers
SOURCE: missing cartridge for the lexmark z1420
Try resetting the ink settings on the printer's program. I use compatable cartidges all the time in my lexmark no problems, as long as i always rest the ink before i start a new one. Try a good clean too. Why are you contacting hp site if your printer is a lexmark. You need the lexmark site. I thought your printer issue is with a lexmark z1420
Posted on Oct 28, 2008
daryn720
  • 113 Answers
SOURCE: Lexmark Z1420 printer just flashes on and off on start button
IF YOU'VE ALREADY TRIED TO UNPLUG AND LET REST AND THAT DID NOT HELP , THEN UN-INSTALL YOUR SOFTWARE OUT OF ADD & REMOVE PROGRAMS AND RE-INSTALL FROM SCRATCH .
Posted on May 07, 2009
jaggujoshi
  • 119 Answers
SOURCE: Have a brand new Lexmark Z1420, the colour ink
Dear,
Goto Printing preference and there you will see that wether there Grascale Printing option may be clicked. There you have to click color option and check it out once. else may be color catridge may dry also.
Cheers
Jaggu
Posted on Oct 01, 2009
bhagyavichar
  • 414 Answers
SOURCE: ''incorrect'' cartridge in lexmark z1420, but its the right one!
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed and call ur system admin....
if all the above fails, then it may b a defective cartridge..!!
Posted on Oct 25, 2009
My printers color won't work, I just filled it with 4.5 ml of each color. the black is also really patchy. I want my lexmark z1420 to just work!!! Help!!!
It could be due to the refilled cartridge in your printer. Refilled cartridges tend to degrade print quality and in performance. Try to replace your cartridges with genuine Lexmark cartridges.
Sep 05, 2011 | Lexmark Z1420 Printer
My Lexmark Z1420 wireless printer used to work perfectly; however, since we moved, I can't get it to work. We have wireless internet. I have reinstalled the driver. I have checked the cables. I...
Your printer may need to be reset. Disconnect your printer from your computer. Unload the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check for any paper jams or obstructions in the paper path and the cartridge carrier's path. If all is clear, close the printer cover. Unplug and re-plug the printer into the power source to reset it.
When the printer turns on, reinsert one cartridge first. Close the cover. Check for any errors. If no error, reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to reinsert a different known working cartridge to determine if the other is faulty.
For your wireless connection problem, you may need to reset the printer's wireless network settings first. Please refer to How to Reset the Z1400 and Z1500 Series Network Settings.
To reconnect the printer to your wireless network, re-launch Lexmark Wireless Setup Utility on your computer.
Jun 21, 2011 | Lexmark Z1420 InkJet Photo Printer
How do i trick my lexmark z1420 refilled catridge to work?
Most lexmark cartridges need a special refill cartridge, I sure hope you did not use one that says recycle on it if so that will not work ever. You need to puchase a compatable refillable cartridge, there is no tricking it to work if you had this cartridge.
Keeep in mind refilled cartriges can damage the system long term so keep that in mind.
Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 11, 2010 | Lexmark Z1420 InkJet Printer
My lexmark z1420 cant print the alignment page, it keeps saying that the protective tape may still be on the cartridges, but it isn't, I've tried putting different cartridges in (the old ones) and it is...
The cartridges may not be seated properly in the carrier or just needs cleaning. Remove the cartridges from the printer. Close the cover of the printer. Unplug the printer from the power source and leave it unplug for now. Here's a link to the Lexmark website to guide you on how to manually clean the nozzles of the cartridges. http://bit.ly/9ZpYd1 . On the page, there are also other instructions on how to maintain the cartridges using the Lexmark software but that's applicable once you have resolved the alignment problem. Plug the printer back to the power source. Once printer's ready, re-insert the cartridges.
Mar 31, 2010 | Lexmark Z1420 Printer
Have a brand new Lexmark Z1420, the colour ink cartridge won't work but the black ink cartridge will (both came with the printer). It thinks there is no colour ink cartridge? I have checked there is no...
Dear,
Cheers
Jaggu
Oct 01, 2009 | Lexmark Z1420 Printer
Where can i buy ink cartridges
You can always get them from Lexmark:
Lexmark Z1420 Supplies
Or any number of places online:
http://www.bizrate.com/inktoner_inkjetcartridges/brand--lexmark/products__att259--43030-.html
Then there's always Staples, Best Buy, Office Max, Wal-Mart, etc.
Thanks for using Fixya.
Sep 03, 2009 | Lexmark Z1420 Printer
Lexmark Z1420 Wont Print
Lexmark has programmed the this printer to ONLY recognize THEIR cartridges! You can not use any thing else except their over priced, half filled cartridges you get at Wally World.
Jun 13, 2009 | Lexmark Z1420 Printer
Low ink
Wow, nice "solution," Printech. That is BS. There has to be a way to trick this printer into using refilled ink. If not, why would they sell refilled ink kits for this printer? Cut the **** and give us a SOLUTION. I refuse to pay $30 for a "certified Lexmark" cartridge when I can spend $15 for a refilled one.
Sep 06, 2008 | Lexmark Z1420 Printer
Missing cartridge for the lexmark z1420
Aug 16, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lemark Z1420 why bother?
ok..the cd drivers MAY not be current go here, and follow link through lexmark icon for latest drivers
remove old software first though
Mar 24, 2008 | Lexmark Z1420 Printer
Lexmark Z1420 InkJet Photo Printer Logo
2,362 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
